Does it only happen when you are using the radio or when you are using the CD as well.
Nissans are notorious for not grounding through the harness and only through the chassis.
In my opinion, The problem may be the fact that you did not properly ground the radio properly, initially, that the radio was using a floating ground and damaged the radio or grounding through the antenna and damaged the antenna. The problem with grounding through the antenna is the fact that because of the resistance, it is not meant to be used as a ground for any electronics, only as a means for a reference for the antenna signal. So the possibility is you may have to change out your radio or the entire antenna, antenna amp, and/or lines.
" In the beginners mind there are many possibilities, but in the experts mind there are few. "- Shunryu Suzuki
PROGRESS:
[DONE&DONE] (Considering a redesign)
