The MP3car.com Store
Thread Tools Display Modes
Old 03-03-2008, 06:57 PM   #1
My Photos: (0)
RC out of factory head
I'm just trying to get rc out from the factory head unit in my '94 Taurus. any suggestions would be appreciated. they're for my new amp, just in case you were wondering.
Butsu is offline   Reply With Quote
Sponsored Links
Old 03-03-2008, 07:06 PM   #2
boomintrac's CarPC Specs
boomintrac's Avatar
Vehicle: A little white wagon
My Photos: (0)
If you dont know the answer to this I would seriously consider paying for the install.
Aron
trukz
boomintrac is offline   Reply With Quote
Old 03-03-2008, 07:17 PM   #3
My Photos: (0)
if you do know, just tell me please
The install is done, except for this. The head unit doesn't have rc out, but I want to use rc's. I'm not an idiot but I can't think of any simple way to do it. So it would be really helpfull if you would answer the question, thanks.
Old 03-03-2008, 07:59 PM   #4
Woofnstuff's CarPC Specs
Woofnstuff's Avatar
My Photos: (10)
something like one of these should do the job
http://www.davidnavone.com/cart.asp?24&cat=7
this is a 4 channel one...bu there are 2 channel ones too
Woofnstuff is offline   Reply With Quote
Old 03-03-2008, 08:20 PM   #5
My Photos: (0)
thanks, that'll do it.
Old 03-04-2008, 05:12 AM   #6
ronjon228's CarPC Specs
ronjon228's Avatar
Vehicle: 1999 Regal LS
My Photos: (0)
Don't be surprised if it sounds like crap. Line level converter are known to cause massive amounts of distortion to the signal. If you invent in an after market head unit you'll surely be happy you did.
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Comps, 2 x 12" Pioneer 305DVC, Visonik V500HC
ronjon228 is offline   Reply With Quote
Old 03-04-2008, 05:25 PM   #7
pancit175's CarPC Specs
Vehicle: 96 Talon
My Photos: (0)
I'm sorry but when you say "rc" I think you really mean "RCA."
I would suggest to pick up an adjustable line out converter to prevent the distortion described above.
" In the beginners mind there are many possibilities, but in the experts mind there are few. "- Shunryu Suzuki
PROGRESS:
[DONE&DONE] (Considering a redesign)
pancit175 is offline   Reply With Quote
Old 03-16-2008, 04:17 PM   #8
My Photos: (0)
Too poor for pre-fab
thanks, but I'm cheap, and kinda lazy, so I just spliced a couple of females into the speaker wire, and ran rca from those leads to my amp. At first I crossed the polarity on one of them, but I got is sorted out, and it sounds great. Thanks for the tips, this seems like a pretty usefull site.
Old 03-16-2008, 06:28 PM   #9
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
there is a reason why they make line -level output converters (LOC), because you should NOT wire a high level (speaker) wire directly into a low level (line-level) input. doing so will overload your amplifier, and it will soon be an expensive paperweight.
many amplifiers have both line-level and speaker-level inputs. you can wire it directly to your speaker wires if you're using the speaker level input. if your amp doesn't have speaker level inputs, then you need to use a line-level output converter. these can be bought very cheap (as low as $10), so there is no excuse not to use one.
FusionFanatic is offline   Reply With Quote
Old 03-16-2008, 08:22 PM   #10
pRoFiT's CarPC Specs
pRoFiT's Avatar
Vehicle: 91/chevy/S-10
My Photos: (2)
Your going to fry your amp.
Go to any stereo place and pick up a line converter or you will also need to buy an amp next.
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
pRoFiT is offline   Reply With Quote
Sponsored Links
Old 03-19-2008, 06:39 PM   #11
My Photos: (0)
my amp does have high level inputs, or I wouldn't have done it. It's doing fine, and I use it a lot. Thanks, for the concern though.
Old 03-20-2008, 06:51 AM   #12
Vehicle: 2004 Volvo S60r
My Photos: (0)
In fact, many amplifiers include differential inputs and a high-level signal can be used on the RCA inputs. The input sensitivity control will have to be turned down, though.
Here's how to tell if your amp is capable:
1. look at the CEA 2006 rating for maximum input signal voltage. If it's better than about 5V, it'll be ok. 6V+ is better.
2. Use an ohm meter to be sure than none of the RCA shield connectors are continuous to each other or continuous to chassis ground.
If your amp meets these two criteria, you can safely connect the speaker outputs directly to the RCA inputs. The benefit of this arrangement is tht the signal will be completely isolated from ground and the input voltage is higher than using RCA outputs. That means NO NOISE.
Andy Wehmeyer
Product Marketing Manager
Harman Consumer Group
Mobile, Portable and Companion Products Division
AWehmeyer is offline   Reply With Quote
Old 03-30-2008, 09:40 PM   #13
pRoFiT's Avatar
My Photos: (2)
I guess you have it working. But it would have been nice to know you had high level inputs from the beginning. Which makes me wonder why you wanted RCA connectors? You could have ran speaker wire from stereo to the amp. The amps I've seen with high level input have a connector with the input wires and not RCA connectors.
Oh well welcome to the forums. More info from the start next time
Old 03-31-2008, 10:06 AM   #14
My Photos: (56)
well that's not what you said earlier. you said "I just spliced a couple of females into the speaker wire, and ran rca from those leads to my amp "...
if your amp has high-level inputs they will be in a wire harness/connector, not RCA inputs. RCA inputs in amplifiers are only used in low/line-level inputs.
your statements contradict each other. what exactly did you do? :?:
Old 03-31-2008, 10:07 AM   #15
My Photos: (56)
Sponsored Links
vB code is On
Trackbacks are Off
head unit or no head unit... that is the question FusionFanatic General Hardware Discussion 49 08-26-2007 11:21 PM
03Honda Accord-How Do I wire another head unit plus keep dual climate stock head unit Thormx037 Car Audio 6 05-11-2007 12:39 AM
So I have decided to change out my factory speakers for something a little better. lawrence Car Audio 12 10-28-2004 06:44 PM
Remote Head unit Eject Problem FIxed! Sporttracguy Car Audio 0 10-02-2004 01:51 PM
New Sony head unit - botched wiring... SamDude Car Audio 4 09-09-2004 04:21 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
