The MP3car.com Store
Thread Tools Display Modes
Old 03-05-2008, 03:32 PM   #1
Vehicle: 2003/Infiniti/G35/Coupe
My Photos: (0)
Subs?
I have a computer enclosed in a metal case (i dont know if thats the problem). I had two subs installed and the computer is located directly behind one of the subs. The next day after installation my computer would not turn on. I checked with an voltmeter and it is still getting juice but the lcd light that indicates power doen not come one and it appears to have no power. I talked with a friends dad and he said that the subs might have fried the hardrive with its electromagnatism. Is this a possability of has my power unit just gone out and needs to be replaced?
Ben
Miserydevined is offline   Reply With Quote
Sponsored Links
Old 03-05-2008, 04:12 PM   #2
rgarjr's CarPC Specs
rgarjr's Avatar
Vehicle: 98 Lexus GS300
My Photos: (37)
Well you definetly dont want any magnets around the hard drives, cuz it will erase everything. If the hard drive got messed up, you will still see the BIOS screen or something on the screen.
rgarjr is offline   Reply With Quote
Old 03-06-2008, 02:27 PM   #3
My Photos: (0)
Ok then i guess its the power suply gone out because i dont have anything at all.
Old 03-06-2008, 02:59 PM   #4
rijk's CarPC Specs
Vehicle: 1994 volvo 440
My Photos: (0)
do you hear a fan? How cold is it, could be cold external temp
rijk is offline   Reply With Quote
Old 03-07-2008, 07:52 AM   #5
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
First off, what kind of computer is it?
Mobo type, processor, desktop, mini atx, laptop, etc?
Could be a failed mobo also.
Does your board have an led that indicates if it is receiving power?
If it's "off", the problem likely resides in the power supply or the feed to it. It could still be a fried mobo though...........
Leonardo Da Vinci
greatwhite is online now   Reply With Quote
Old 03-07-2008, 01:26 PM   #6
My Photos: (0)
Thats the problem i dont know what kind of computer it is. I baught the car and it was in it. I didnt have a problem until i installed the subs. However it was the same time as winter also. It was in the low 20's for a while there but it warmed up for a couple of weeks and still did not work.
Yes there is a LED light but it wont light up at all so thats what makes me think it is the power suply because i checked the wire that connects into it and it has power.
Old 03-07-2008, 02:00 PM   #7
greatwhite's Avatar
My Photos: (1)
Is it a p4?
A mobile?
Celeron?
Look for identification marks on the board-google is your freind there.
What kind of ps? DC-DC? Inverter?
Does it have an atx connector? If it does, try another PS from a desktop and plug it inot the wall. If the led comes on, the ps was bad. If it doesn't, you've got a mobo problem. if it posts and doesn't boot, harddrive problem.
It's possible you wiped the mobo's bios chip with the sub magnet depending on exactly what happened when you installed it.
Sorry, but you're just not giving out enough info here for even an educated guess. These are just "stabs in the dark".
Good luck
Leonardo Da Vinci
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: What speakers/amps should I go with? RedGTiVR6 Car Audio FAQ 9 07-13-2007 07:43 AM
What's good, what's not so good (Car Audio Products) rijndael Car Audio 2 05-25-2007 10:48 PM
Low-budget SPL Subs SuprchargdMazda Car Audio 13 05-24-2006 02:33 AM
Soundblaster not pushing my subs... 3onDubs Car Audio 12 11-21-2005 04:27 AM
FS: 2 mtx 10 inch subs and 400 watt amp with box xdjxklusivex Classified Archive 0 02-25-2005 03:41 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
