The MP3car.com Store
Thread Tools Display Modes
Old 03-10-2008, 03:45 PM   #1
My Photos: (0)
Pioneer Ip-Bus Dual inputs?
Hey guys -
I've got a P7700MP and I am trying to hook up my XM and an Ipod to the unit..
Both setups use the same input ip-bus jack.. So in order to hook both units to the headunit, I am going to have to hack into the ip-bus cord and wire in a seperate ip-bus cord for one of the items.. Essentially making my own Y-ipbus cord..
Well, I was sorting out the issue in the car a bit ago and noticed when I select the "aux" channel, XM plays through both it and the "xm" selection - which is pretty much to be expected..
So, if I simply wire in the new ipbus cord for the ipod, i'm going to hear ipod and xm through the aux channel.. Right?
Now - what I am thinking is, I could easily wire in an on/off switch to both the XM power wire and the Ipod power wire and just flip one of them off when I want to hear the other one..
Pretty simple and should work fine, I just thought I'd see if anyone had handled this another way before I started hackin' into my wires..
Thanks guys..
Jeff
Tram is offline   Reply With Quote
Sponsored Links
Old 03-11-2008, 10:54 AM   #2
My Photos: (0)
I had this problem. What I ended up doing to correct it was buying Pioneer's XM tuner. This has an IP bus input and IP output. All the switching is done from the controller box and saves you from unnecessary work and modifications.
The model you want it GEX-P920XM, and XM should activate the new radio for free as long as you tell them that the XM direct one stopped working.
lostvoid is offline   Reply With Quote
Old 03-12-2008, 10:33 AM   #3
My Photos: (0)
Thanks for the reply...
I think I may just still try hacking into the ip-bus.. I don't mind doing it and if I put an on/off switch on the power line to the XM radio, I should solve my issues..
Jeff
Sponsored Links
vB code is On
Trackbacks are Off
Pioneer Ip Bus: What can it control? Ibanez General MP3Car Discussion 5 02-17-2008 03:13 PM
pioneer ip bus? nfgrulez General Hardware Discussion 5 10-10-2006 12:36 AM
Anybody know where to get a Pioneer IP bus to RCA adapter? ryan212 General Hardware Discussion 8 01-24-2001 01:24 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
