The MP3car.com Store
Thread Tools Display Modes
Old 03-12-2008, 06:20 PM   #1
Nola111's CarPC Specs
Nola111's Avatar
Vehicle: 2006 VW Passat 2.0t
My Photos: (1)
Auzentech Card: can't get sound out of the sub channel (again)
Hey all,
I'm having issues getting sound to my sub out of of my Auzentech Prelude card. Since it uses Creative software, I followed the instructions in the following post that I found by searching...
http://www.mp3car.com/vbulletin/975373-post5.html
The key was using a y-splitter, and lo and behold, I got sound to the sub! Good right? Well no, because after two days, the card stopped sending the signal to the sub. (I know it's not the sub b/c I hooked an mp3 player to it to test it... the sub is fine).
The absolute only thing I did between the time the sub worked and didn't work, was install RoadRunner. (I use Centrafuse mainly). Installing RR couldn't have done anything, huh? So now, I've gone over and over and repeated the steps in the above post, and I can't get sound out of the sub/center channel of the card.
Does anyone have any ideas of something else I should try?
Thanks!
Nola111 is offline   Reply With Quote
Sponsored Links
Old 03-13-2008, 10:06 AM   #2
hithere's CarPC Specs
Vehicle: 06 Acura TL
My Photos: (0)
Quote: Originally Posted by Nola111 View Post
Hey all,
Thanks!
You know, I've had to fight with Creative software in the past and making sure it reads the same in terms of speaker setup (4.1, 2.1, 5.1, etc.) as it does under Windows speakers/audio control panel. Start from Road Runner/Winamp, move to creative setup, then check the control panel, in each place making sure that your speaker layout is reflected correctly.
hithere is offline   Reply With Quote
Old 03-13-2008, 10:29 AM   #3
Nola111's Avatar
My Photos: (1)
Hi there hithere. Thanks for the reply. Actually, I don't even think I'm going to use RR anyway, mainly Centrafuse. It worked fine in there for awhile and now nothing. I would uninstall RR, but for one, I can't see how installing RR would have mucked something up that bad, and two, I still would like to have it on my system even though I won't be using it as my main F/E.
What's strange is that I followed durwood's instructions, got it working, and now nothing, even when repeating durwood's instructions.
The software is a little bit different from older Creative cards but for the most part it has all the same, or similar settings. In fact, the software I have has an option to boost the subwoofer output by +15db... in the same section that the "Enable Bass Redirection" option is in. Having both those ticked really did the trick last time. Now, nothing.
Sponsored Links
vB code is On
Trackbacks are Off
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 80 07-16-2008 12:42 PM
usb sound card gti4dr General Hardware Discussion 2 10-16-2007 07:24 AM
Advise on usb sound card Kimota General Hardware Discussion 1 09-11-2007 01:45 PM
Added USB Creative Sound Blaster, now my TV/FM CARD sound needs a line in? clean customs Car Audio 5 02-03-2005 01:43 PM
Sound card reccomendation for **music** TWBarrett Car Audio 12 09-09-2004 09:40 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
