The MP3car.com Store
Thread Tools Display Modes
Old 03-13-2008, 09:59 PM   #1
My Photos: (0)
Selectable multiple input sound card
Hi all,
I've searched and can't find this. I need to input 3 or more (3 will do for now) different sources into the carpc, then select the one I want to use via software and output it to the audio system. I can't find a card that will do just this. I don't want to simultaneously use the inputs, as in mixing them into one output. Maybe I'm searching on the wrong words. Like I say, I've found lots for mixing/simultaneously recording multiple inputs, that I don't want that. I only want one input routed to the output at a time. I know I can simply put a hardware switch in before the input, and manually control it, but that isn't what carpc's are all about. I would like the frontend (haven't settled on a specific one yet) to select the audio/video from my backup cam/sirius radio/aux-in/ or whatever and route it out to the amps. Is there such a thing? I've read that multiple USB sound cards are unstable, and not sure that would do what I want anyway.
waterskier1 is offline   Reply With Quote
Sponsored Links
Old 03-14-2008, 12:53 AM   #2
rgarjr's CarPC Specs
rgarjr's Avatar
Vehicle: 98 Lexus GS300
My Photos: (37)
Good luck in finding one, mostly all cards just have line in and mic.
rgarjr is offline   Reply With Quote
Old 03-14-2008, 03:02 PM   #3
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
Fusion Brain has to ability to control relays via software.
You could use that to switch the inputs to one main input.
Otherwise you need to look at pro audio cards that have assignable inputs and outputs simialr to a mixer. Softare intergration will be a pain, but anything is possible.
durwood is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
VIA EN1500G Faulty Sound Card? Splash-X General Hardware Discussion 2 12-16-2007 10:27 AM
Opinions on an AuzenTech HDA X-PLOSION sound card? greatwhite Car Audio 4 10-31-2007 10:06 AM
usb sound card gti4dr General Hardware Discussion 2 10-16-2007 07:24 AM
Audiotrak Prodigy 7.1 HIFI Sound Card Instructions waynebosz Newbie 0 07-09-2007 11:51 PM
Need advice on which sound card to use mtmsol General Hardware Discussion 2 06-22-2001 12:39 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
