The MP3car.com Store
Thread Tools Display Modes
Old 03-16-2008, 04:28 PM   #16
bes51659's CarPC Specs
bes51659's Avatar
Vehicle: 01/BMW/325ti
My Photos: (6)
Sorry, can't help you there. I've not installed in car yet, so I still live in the pretens that gain is sufficient and that I won't need a preamp.
Sure a PC can sound good! About the board you've got I got a bit suspicious about "award winning new tech to restore lost info in mp3's" and "turn your hifi int xtreme-fi".. I like info like 24-bit DAC, 100dB S/N, etc. :-)
There is some interesting sw to measure your car coupe and compensate for timedelays, and digital filters that you run as batch jobs on your music and therefore has 0 phase error etc! Its a jungle, but its going to be fun to dig into that. Plenty of info on mp3car.
I saw that there are some carputer people have bought fosgate 360. Why in gods name when you got a PC at hand. Its only a bunch of filters at $1000. - At last a reason to motivate a PC heavy investment to the girlfriend :-)
bes51659 is offline   Reply With Quote
Sponsored Links
Old 03-17-2008, 06:57 PM   #17
z_lust's CarPC Specs
Vehicle: '96 Nissan 300zx-TT
My Photos: (0)
The loss of gain you are experiencing is because you are only using half of the balanced input to the amp. This translates to about a 6db loss. Your pre amp (Turbo1) can make up this gain, but because you are still only using half of the input signal you are overdriving the amp into distortion when you make up the gain you are loosing due to being unbalanced.
If you use balancing transformers (one for each powered speaker) you should get your gain back with clear sound.
Make sure your transformers are 0db gain or up to +12 db gain. Some transformers (like inexpensive Direct Boxes) will drop your gain up to 20db.
Using outboard DSP (like I'm doing here: http://www.mp3car.com/vbulletin/work...m-upgrade.html ) is far more affective than using the PC or even batch processing your media (that sounds like a nightmare).
z_lust is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Computer audio noise from Intel 2 ghz mini dogpilot MacCar 10 11-20-2007 09:52 PM
Alternator Whine Only With Carputer tbird2340 Car Audio 25 06-29-2007 02:36 AM
Inverter Question phatchink Power Supplies 27 08-21-2006 12:45 PM
Noise (from engine and other sources) HELP!!! sstylos Car Audio 6 09-20-2005 12:41 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
