The MP3car.com Store
Thread Tools Display Modes
Old 03-14-2008, 11:44 AM   #1
Vehicle: 99 Ford Focus
My Photos: (0)
Subwoofer, quick question....
I've bought a new headunit and have everything wired and hooked up except the switch signal that hooks up to the ACC on the the back of the headunit. I guess its the line that goes to ground when the key is not turned in the ignition.
Anyway i noticed that the red/white sub output cables have another small wire running the along them that I had ignored before now. I assumed it was something to do with grounding and I ignored it.
Its a very thin piece of wire, can I used this to send the ACC signal to the sub to switch it on or off?
thanks in advance!
quarryman is offline   Reply With Quote
Sponsored Links
Old 03-14-2008, 02:05 PM   #2
My Photos: (0)
thanks in advance!
Thats exactly what it is for. It is the remote switch wire that turns on your amp. I put a thicker wire to do that, but what you have will work.
It connects to the amp and then on the receiver it connects to the blue wire with the white line on it. Then youre good to go!
fbcbeer is offline   Reply With Quote
Old 03-14-2008, 02:55 PM   #3
ronjon228's CarPC Specs
ronjon228's Avatar
Vehicle: 1999 Regal LS
My Photos: (0)
While fbcbeer is right, I will add something. Your remote wire can be basically any gauge. Size doesn't matter as it's just a signal wire, it carries minute amount of current.
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Comps, 2 x 12" Pioneer 305DVC, Visonik V500HC
ronjon228 is offline   Reply With Quote
Old 03-14-2008, 03:00 PM   #4
My Photos: (0)
The reason why I went with a little bigger wire (18 guage) is because I didnt want the tiny signal wire between my RFosgate RCAs to kink and stop the signal at any point.
Either way will work great!
Old 04-02-2008, 03:26 AM   #5
My Photos: (0)
Bit late now, forgot to reply!
Went with the small gauge cable and it worked perfect!
thanks.
Sponsored Links
vB code is On
Trackbacks are Off
Subwoofer boxes / cases - quick question Pabs Car Audio 8 12-02-2004 02:24 PM
Quick question on kiosk Gavc General Hardware Discussion 0 11-10-2004 09:16 PM
Quick grounding question GingerPrince Power Supplies 6 11-06-2004 08:28 PM
quick question about dc voltage cdm Power Supplies 4 03-05-2004 03:19 AM
quick fuse question.... jusatry General Hardware Discussion 2 02-23-2004 10:54 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
