Old 03-15-2008, 03:48 PM   #1
kantlivelong is an unknown quantity at this point
Question Gain settings...
Hey all,
I have a Power Acoustik SL4-1000 amp and am using a Fusion FX-45 equalizer/linedriver that puts out 8VRMS to the amp. My speakers are MB Quart RVF 216 and MB Quart RVF 269.
Right now i have them set at 1/2 for both sets of speakers.
- Should i be able to turn the gain on the amps all the way up? Or does it not work that way...?
-Sometimes the rear ones pop on certain frequencies. Is there any good set of frequencies to test for popping?
kantlivelong is offline   Reply With Quote
Advertisement Sponsored links
Old 03-15-2008, 04:12 PM   #2
lbridges is an unknown quantity at this point
It does not work that way. One way (for the mid-bass, door type speakers, not tweeters) is to play back a single frequency sine tone and adjust gain until you hear the speaker slightly change frequency (it does that because the gain is too high and square waves - with higher frequency content - are being generated). There are a lot ways. most any car audio forum would probably have this topic addressed many times.
lbridges is offline   Reply With Quote
Old 03-22-2008, 07:27 PM   #3
ArcaneDreams is an unknown quantity at this point
You will never have to turn your gain up all the way. Never ever..ever..
As I said in another thread:
Quote:
Your crossover controls what frequency will be cut off from your sub. That is mainly personal preference, but you have to take into account what frequency your box is tuned to.
To set the gain:
1. Turn all your bass/treble settings to 0.
2. Put in a CD/Song you know well that represents the type of music you will be playing generally.
3. Turn the volume knob up to your usual listening level.
4. Slowly turn up the gain knob until you just start to hear some distortion coming from your sub..then back it down a bit to just under that distortion level.
5. Adjust your bass/treble boosts to your pleasure. Be careful not to overdue the bass boost.
And remember, gain is not volume!!!
ArcaneDreams is offline   Reply With Quote
Old 03-23-2008, 03:46 PM   #4
atoz350 is an unknown quantity at this point
Btw the way the popping from MB quarts comes from having the crossovers set too low. Turn your high pass (hp) filter on and set it until the popping goes away. Those speakers are not meant to play low frequencies. You'll need a subwoofer to cover that. I suggest you go to www.diyma.com/forum or www.caraudio.com/forum for more information on this subject.
atoz350 is offline   Reply With Quote
Old 03-23-2008, 03:49 PM   #5
Okay since the forum won't let me edit my post...the first link doesn't work. Try this one: www.diymobileaudio.com/forum
Holux GPS Trouble mangus580 StreetDeck 34 11-26-2007 09:56 PM
