Notices
Old 03-15-2008, 05:41 PM   #1
rgarjr's Avatar
SP/DIF to analog rca converter
I'm running a Aopen mini pc onboard sound going to car amplifier and as some of you know, some noise gets introduced from the hard drive, gps nav receiver, or what not. I'm gonna try and isolate the noise by using the SPDIF output port.
Question on the Sound Blaster Audigy 2 NX card's optical in/out.. If you feed audio to the line in (via 3.5mm plug) does that get come out of the optical out port or no?
rgarjr is offline   Reply With Quote
Old 03-15-2008, 11:57 PM   #2
MySQL Error
scott_fx's Avatar
you have a lot of options and probably a lot of higher quality options as well. do a search for 'dac' or look at some of the stickies.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 03-25-2008, 01:26 AM   #3
I have the same question about the use of a Sound Blaster Audigy 2 NX.
Sadly the stickies didn't yeild anything I could use, i'll keep looking
THis was a good start
http://www.mp3car.com/vbulletin/car-...digy-2-nx.html
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
Kosti is offline   Reply With Quote
Old 03-25-2008, 01:31 AM   #4
MySQL Error
scott_fx's Avatar
no, 3.5" is usually unbalanced analog. what you're trying to do would require a dac before you went into the soundcard...which would be pointless
M10k
My Car Pc Install
Old 03-26-2008, 09:20 AM   #5
I do believe the NX has a coax digital 3.5mm input port, but I think what he's asking is if the sound card will do a A/D conversion from it's line in and output over optical. And it's not pointless, if you're trying to consolidate multiple inputs, either digital or analog, to a single optical due to equipment limitations on the other end. For example, you have an amp or processor with a single digital input and you have multiple sources which include a PC (sat radio, HD radio, etc.). I know because I was trying to do something similar at one point...
In answer to the OP, if the above is what you're asking, I believe it's possible, but I couldn't find any way to make it work reliably on my Audigy 2 NX...
hithere is offline   Reply With Quote
Old 03-26-2008, 08:21 PM   #6
MySQL Error
scott_fx's Avatar
is there a car audio amp has a digital input?
also, never seen a digital in with 3.5mm you need a 75 ohm cable and most commonly terminated using an rca. never seen it any other way. unless you have a aes that uses an xlr
M10k
My Car Pc Install
Old 03-27-2008, 09:59 AM   #7
its not that simple
http://www.mp3car.com/vbulletin/car-...al-inputs.html
wirelessdreamer is offline   Reply With Quote
Old 03-27-2008, 12:38 PM   #8
MySQL Error
scott_fx's Avatar
i guess i should have rephrased that, does his amp have digital input
M10k
My Car Pc Install
Old 03-28-2008, 02:45 AM   #9
rgarjr's Avatar
For owners of the 2 NX card, if you feed it audio off the 3.5mm line in jack, it will output that off the S/PDIF output. Just a fyi.
My carpc worklog
Rear view cam choice: RCA to USB converter vs composite input card. stonestatue LCD/Display 5 01-14-2008 02:37 AM
1999 Mercury Sable RCA Converter question xxgmsmgxx89 Power Supplies 1 04-22-2007 06:54 AM
convert Toslink to 5.1 Analog RCA (6 RCA Plugs) jayroo5245 Car Audio 5 04-11-2007 01:48 PM
stereo to rca converter, no loss in sound quality? emdzey01 Car Audio 9 02-14-2005 12:14 AM
Digital to Analog Converter Maukio Car Audio 0 02-01-2005 12:58 AM
