The MP3car.com Store
Thread Tools Display Modes
Old 03-16-2008, 10:42 AM   #1
My Photos: (0)
Question Whole System Issue
This is the situation... I have a 2004 Accord with 2x12" on a 1000w amp and the stock 6.5's in the front and replacement 6x9's in the back... Everything has been working peachy keen for about a year but about a week ago I noticed my subs we not hitting.. After a brief inspection of the wires making sure everything was secure they were still not hitting (power light active). So after checking over the wires once or twice more I get back in the car and continue driving... But now an awful crackling is coming from all 4 speakers (sub and amp are disconnected at this point).
So today I finally got a change to look it over and it really seems nothing is out of the ordinary unless I'm looking in the wrong places. I checked the connections in the back of the head unit all the way to the speakers. The wiring of the regular speakers is completely stock with the exception that I had to shave some plastic off of the back wire so I could attach the speaker wire for the 6x9's I replaced (Accord have the 'clip in' type of speaker connection). Since that is the only altercation I have made (besides sub/amp which are completely disconnected) I would think that is the problem point but even when I disconnect the back 2 6x9's the front 6.5's still sound super blown which is really ****ing me off because that is still stock ****.
What could my problem possibly be?
Also: I use the stock head unit with a high-low converter but shouldn't matter, it is disconnected at this point.
Tosi is offline   Reply With Quote
Sponsored Links
Old 03-17-2008, 08:57 AM   #2
hithere's CarPC Specs
Vehicle: 06 Acura TL
My Photos: (0)
Is/was the stock head unit handling power for the 6X9's and the stock front?
Being as the sound is coming from all four speakers at once, I'd at least check over stock connections for the head unit, including system ground...and I wouldn't be at all surprised to find a shakey +12V (check ACC, if that's what you were using to remote your aftermarket amp) wire or loose speaker connection. That, and a dusty potentiometer (volume knob internals) or other internal dust can cause that kind of noise in all speakers...
hithere is offline   Reply With Quote
Old 03-22-2008, 06:24 PM   #3
My Photos: (0)
Sounds like a problem I had when I first started getting into car audio. Turns out my head unit's outputs were bad.
They became bad because I was running too many speakers in parallel..causing the ohms to drop to almost nothing.
However you said you messed around with the connections and produced a new problem.
I suggest unhooking everything, then re-doing it all over again making sure all the connections are clean and tight.
ArcaneDreams is offline   Reply With Quote
Old 03-26-2008, 05:42 PM   #4
Vehicle: 1995 Toyota Celica st202
My Photos: (0)
just new here so browsing over the threads!
As arcane said if your using the stock headunit it's properly low on outp
slick_celica is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
1996 300zx TT - Carputer w/ sound system upgrade z_lust Worklogs 17 06-30-2008 11:04 AM
New EWF + MinLogon and CF instructions SFiorito WinNT Based 252 05-28-2008 02:22 PM
Escalade PC and Audio System Install accentsound Car Audio 3 11-02-2005 11:50 AM
My dilemma, please help me decide on a system Will Albers General Hardware Discussion 13 09-29-2005 12:28 PM
Ground noise in system TyBong General MP3Car Discussion 10 09-20-2005 02:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
