The MP3car.com Store
Thread Tools Display Modes
Old 03-16-2008, 01:49 PM   #1
My Photos: (0)
VenHaus braided speaker wire pic!
Here is a shot of my, just finished, sub speaker wire (for single 10")...
It's equivilent to 10 gauge...
You can see beside the 14-16 gauge driver wire just how robust it is!
It's basically 3 driver wires braided together. Thank God I only needed a short run!
And a pic of the wire for use off the crossover to the tweeter...
And what I had to work with...
WuNgUn is offline   Reply With Quote
Sponsored Links
Old 03-16-2008, 03:16 PM   #2
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (129)
and this does what?
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 03-16-2008, 03:36 PM   #3
mezz64's CarPC Specs
mezz64's Avatar
Vehicle: 98 Honda CRV
My Photos: (1)
First question, stranded or solid, it looks solid in the photos. If it's solid I'd be concerned how well that is going to hold up in a car environment. And along the same lines I'd be all for such an elaborate cable in a home setup, but do you really think the difference will be evident in a moving vehicle?
Just my 2 cents.
98' Honda CR-V
http://www.superbluecrv.com
mezz64 is offline   Reply With Quote
Old 03-16-2008, 03:41 PM   #4
nobb's CarPC Specs
My Photos: (14)
I think he is braiding cat5 cable like that to make the cable low inductance and improve audio quality (faster signal risetime I think?). I doubt it is humanly possible to actually hear a difference though.
nobb is offline   Reply With Quote
Old 03-16-2008, 04:15 PM   #5
My Photos: (0)
Maybe, maybe not...
But there are plenty of reviews available...
And in a environment as noisey as a cars, wouldn't you want to try and achieve the best audio reproduction you can because of this fact??
I mean, because it's not the best environment doesn't mean you can or should get away with 'so-so' quality, right?
Old 03-17-2008, 09:58 AM   #6
hithere's CarPC Specs
Vehicle: 06 Acura TL
My Photos: (0)
I agree with the goal of achieving the best reproduction possible...but I have a real hard time believing that inductance is an issue for subwoofer frequencies assuming even mediocre speaker cable over anything less than miles of distance.
Doing this for subwoofer speaker cable only further adds to the ridiculousness of applying inductance concerns to speaker wire in distances measured in feet. The inductance measured in such cable over those types of runs affects the audio in no audible way, as well as any effects being orders of magnitude below the speaker's own accuracy.
hithere is offline   Reply With Quote
Old 03-17-2008, 10:40 AM   #7
boomintrac's CarPC Specs
boomintrac's Avatar
Vehicle: A little white wagon
My Photos: (0)
If he will be competing this is one of the detail things they will look at. If not others like veerything to look uniform, whats wrong with that? The end result will look much more like a finished product.
Aron
trukz
boomintrac is offline   Reply With Quote
Old 03-17-2008, 10:49 AM   #8
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
I'd be worried about how well that would hold up in the car. The insulation is very thin and can easily get snagged on sharp metal, even if you are trying to be careful.
Second, let's assume such a great claim as "rise time". Rise time of what exactly?
Anyone considering this, please do not blindly follow marketing but be willing to question the claims made.
Any wire, over a short distance (meaning <500ft) can easily carry audio bandwidth signals between 20-20Khz. It can be calculated using R/L/C values plugged into basic filtering formulas.
durwood is offline   Reply With Quote
Old 03-22-2008, 05:59 PM   #9
My Photos: (0)
Well, braiding the wires does help with the signal. If you don't have braided wire you get magnetic fields and the like all messing up your signal.
However, why not just buy some pre-braided 10awg? Its not that expensive and you wouldn't have to spend hours on it.
Plus they are insulated with nice thick rubber.
You are silly...
ArcaneDreams is offline   Reply With Quote
Old 03-26-2008, 02:45 PM   #10
My Photos: (0)
Braiding wire can help minimize the wire's inductance characteristic...but, especially for low-end frequencies in the range of human hearing, for wire that is some feet (and not miles) in length, this is akin to cleaning old french fries from under your seats in order to reduce your car's weight and make it faster in the quarter-mile.
Sponsored Links
Old 03-26-2008, 07:31 PM   #11
My Photos: (0)
I have taken many years of electronics classes. I know the formulas and all that. I was simply pointing out WHY he did do it, and that it was silly in the first place.
By the way, we experimented with a similar scenario in class. We took straight wire and braided wire (a few feet), and ran various signals through them and monitored the oscilloscope.
The braided wire had a crisp and clean signal, while the straight wire was fuzzy around the edges.
Old 03-26-2008, 08:50 PM   #12
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
you mean that doesn't work? ...dammit!
I threw away all those fries for nothing!
FusionFanatic is offline   Reply With Quote
Old 03-27-2008, 07:01 AM   #13
My Photos: (0)
I saved my fries to offer to unsuspecting passengers...
Old 03-27-2008, 07:03 AM   #14
My Photos: (0)
And why this is silly again?? I'll take the clean signal over the 'fuzzy' signal any day...
Old 03-27-2008, 07:16 AM   #15
My Photos: (0)
Because the fuzz is likely noise somewhere in the MHz region.
Sponsored Links
vB code is On
Trackbacks are Off
Broken speaker wire fluffy2097 Car Audio 13 12-06-2006 09:47 PM
RCA to Speaker wire? greenglo General Hardware Discussion 3 02-16-2004 02:20 PM
How to wire a 4 spkr system with 2 speakers coscar Newbie 3 02-15-2004 09:57 PM
ignition wire for opus psu liquid_smoke Power Supplies 3 09-09-2003 10:58 PM
PSU power over speaker wire??? Defiler Power Supplies 12 02-20-2003 06:48 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
