So i tried to install my amp today and it didnt work.....
steps i did.
1. disconnect negative battery
2. pulled a wire from battery(+) to amp -Not connected yet
3. Connected ampflier ground
4. Routed 4 RCA cables(2front 2 rear) + blue amp on remote to amp from HU. I connected the blue amp remote from amp to a blue/white wire in my HU. My HU is
http://www.corral.net/Tech/Audio/sonymp3player/Page_04
5. i connected the subwoofer to the amp using the 2 rear rca outputs from the amp.
Then i put in the fuse which connects to the battery(+), and replugged the negative terminal.
Now the amp doesn't seem to turn on. My original 4 speakers still work. When i turn off my car, the HU starts beeping, which signals that the detachable faceplate is not removed. However, the HU guide said the beeping will stop if i connect it to an external AMP. So....how would you go about trouble shooting it?
How can u tell if your fuse or equipment is dead??:X
