If you are going with an amp, presumably mounted in the trunk, you would connect pc-> amp with rca, amp directly to speaker wires.
To connect to speaker wires you would have to run speaker cable from the trunk and either use a harness (like what you linked to) or splice directly to speaker wires in the stock head unit location.
You really have to define what you want. ie amp or not / new head unit with aux in etc...
