Quote: Originally Posted by
chris350
Ok, so here is my question.....the audio that comes out of a carpc is usually 2 channels of audio. there are four speakers in my car...how do i get audio from 2 channels to 4 channels..what are my options? spilting 2 channels to 4 channels? audio card with 4 channels?
Indeed, that are the 2 most important options you just named...
You will need an amplifier between your pc and your speakers. Most flexibility is reached if you use a 4ch amp with a 4ch (or 5.1) sound card. Keep in mind that the drivers must support 4.0 sound if you use a 5.1 or 7.1 card, otherwise you will lose all sound that's meant to come out of the center speaker and sub...
You can also go the easy way and buy a USB connected amplifier...
Good luck!
Joachim
