Old 03-27-2008, 10:21 PM   #1
Dougw133 is an unknown quantity at this point
Amp Clipping/Only Rear from Soundcard
ok...I have a CARPC using an older Soundblaster Live 5.1 Card with the KX drivers. The card works great, the SQ is great, and I haven't had any PC related pronlems. I have the Sound Card going into a rockford fosgate 3sixty.1 and then to my amps, then to 4 sets of Compnents (POLK). If I try to match the Db or output to the rear spweakers as I have for the front, the amp cuts out for all 4 speakers. I have tried the setup without the 3sixty.1 involved and same result. I can crank the fronts until my ears bleed. But for as high as i can bring up the rear speakers until they clip/cut the amp, I might as well not even have rear speakers. Any ideas? Too much power from the sound card for the amp to handle? Why only the rear? Does my amp just suck?> It is a 4 channel Pioneer GM-6300F with all the Ohms and power outputs correct for the Componets (Polk DB) I am using. Any ideas?? Thanks....
Dougw133 is offline   Reply With Quote
Old 03-28-2008, 02:35 AM   #2
Update...I was driving out tonight, and messing with settings...For a good period of time, It didn't even clip/ cut out...?? I cranked the rears! Then upon reboot the next time it was back to square on...I do not get it...
Old 03-29-2008, 08:27 PM   #3
pancit175 is on a distinguished road
What happens when you switch the signal lines between the fronts<->rears? Either before the 3sixty.1 or before the amps.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 03-29-2008, 08:59 PM   #4
NotYou is on a distinguished road
Since you got it to work at least once without any issues, then your more then likely looking at either a bad technical connection (wire, ground, etc.) or a setting that you changed.
What did you change when you were "messing with settings"? Did you find one that works ok, then if you change it then it goes to not working?
MY GUESS.. would be something to do with the wiring. Try what pancit175 said and swap the wires you are using from the fronts to the rears. If that fixes the issue, then you had a bad connection somewhere. Bad adapter, pinched cable, something not screwed/attached correctly or tightly, etc. Follow all the wires you are using, all the way from the PC to the speakers. Try also making it the shortest/simplist connection possible, just for troubleshooting.
Try hooking the rear wires up the front speakers and see if you have the same problem. If that works fine, then you may have a blown speaker or a speaker wired in reverse.
Best advice I can give is to play around with the wiring, finding out exactly what works and doesn't. Make notes, eliminate as much as you can as a solution and go from there.
NotYou is offline   Reply With Quote
Old 03-30-2008, 01:40 AM   #5
I have tried the swap and nothing helped..What I was doing is lowering the db in the KX Driver Setting...So it will all work, but the rears are about half the output than the fronts. The voltages coming from the souncard are all the same..I am thinking it could be the amp. I have a capacitor and the voltage stays around 13.5 to 14V. Like I said, I can crank the fronts like a madman but...The 4 components, front and rear are all identical Polk MM6500. I know the ground is good. So, I guess it will take a lot more trouble shooting...Thanks...
Old 03-31-2008, 02:33 AM   #6
Nothing has worked... It's definately to do with only the rear output from the soundcard. If I switch the rear output to the front input for the AMP it clips it. But the voltages seem to be very close on both sets of RCA's? I don't get it. Anyone have Sound Blaster Live PCI running to an amp?? Any problems?
Old 03-31-2008, 02:47 AM   #7
Ok... I am seeing my amp has a S/N ratio of 95db. The card is rated at 96db..Would that matter? Now when it "clips/cuts out" I can still here music very faintly. It does not go into any kind of protect mode or power off/blink. The voltage to the amp remains steady. I feel as if I am throwing off the ohms or conflicting something here. It says the input voltages are as follows. 0.8 - 26V, 0.2 - 6.5V . I assume the first set is for 2 Channel mode, and the second for 4 channel?
Old 03-31-2008, 10:44 AM   #8
hari-bhari can only hope to improve
thats strange. i had cutting out on my speakers when i had a pinched. cable that was shorting. try resetting your kx dsp back to default and see what happens. also check your volume in winamp as well as your individual wave and master volumes. if i turn my winamp and wave volume both up, i get clipping. try keeping your winamp volume real low, around 15% and see what happens. also check the gains on your amp.
hari-bhari is offline   Reply With Quote
Old 03-31-2008, 02:31 PM   #9
If you switched the front and rear inputs to the amp and the rear outputs going to the fronts becomes louder to the point that it distorts then I'd guess that something is wrong with the amp.
PROGRESS:
Old 03-31-2008, 03:21 PM   #10
ronjon228's Avatar
ronjon228 is on a distinguished road
This may be related to the output on the sound card. The factory front outputs on the SB Live 512 cards is known to have an inferior output DAC compared to the other outputs. I would try using your factory rear output, and the headphone output. Make sure to turn on headphone/center sub swap AND front/rear swap on in your Kx mixer. Then use the first and the last plug for your outputs. If you need help, let me know. I can send you some screen shots of my DSP and mixer setup. I'm using this setup now and it sound crisp and clean.
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
ronjon228 is offline   Reply With Quote
Old 04-01-2008, 03:25 PM   #11
Ok thank you..Yeah, I currently have WAV at 75%, KX db around -4 for the front and at -21 to prevent the rear clipping, and the Winamp is 100%. Now, If I were to drop my winamp to 15% I would barely get loud enough.. I'll mess around with now and let ya know.. I also do have the DSP to default.
Old 04-03-2008, 01:24 AM   #12
SOLVED: Alrighty. Went to disconnect the Rear Speaker wires from the amp and noticed something odd. With only one wire from the right rear speaker connected, there was still sound. I then noticed that the rear speakers sounded "unequal". So it baffled me how with only the Posotive wire attatched to the amp that there was still sound. So, upon opening my rear door panel the speaker moved and the sound became 100% clear. It now became aparent that the bracket on the speaker where the posotive and negative wires attach, had come into contact with the body and had been grounding itself throughout. Once I readjusted the speaker and secured it better, wola...PERFECT, LOUD, Crisp sound...Thank you all.....I feel stupid now.
Old 04-03-2008, 10:43 AM   #13
Good deal, glad you got it working. Was a wiring issue as many suggested, albeit an odd one. =)
[CoupeE46] BMW E46 2001 330ci CarPC ... CoupeE46 Worklogs 54 10-02-2008 08:16 AM
YES!!! Yet Another Amp Problem CaptainTrap Car Audio 20 03-24-2007 10:58 PM
Could my amp be bad or did i miss something? sansoo24 Car Audio 20 03-05-2007 02:45 AM
Amp behavior. enitalp Car Audio 1 05-01-2006 09:06 AM
Sound quality from soundcard to amp? senseless228 Newbie 5 04-16-2005 06:11 AM
