The MP3car.com Store
Thread Tools Display Modes
Old 03-28-2008, 07:21 PM   #1
Dramey's CarPC Specs
Vehicle: 2001 Explorer Sport
My Photos: (0)
X-FI Noise when booting
I just replaced my USB sound card with an X-FI. When the PC is booting I get a noise that sounds a lot like alternator whine but as soon as windows comes up, it's dead quiet again. Other than that it sounds great. It's not a deal breaker, just wondering if there is an easy solution.
Dramey is offline   Reply With Quote
Sponsored Links
Old 03-28-2008, 10:23 PM   #2
ronjon228's CarPC Specs
ronjon228's Avatar
Vehicle: 1999 Regal LS
My Photos: (0)
I'm wondering if there is any way to hook up some kind of relay or program on the computer then using a serial or USB port to power on the amps. I too have problems with noise during start up (especially on hibernate) and this would be very helpful for me.
The reason you have noise now is because you're using a PCI card that is turned on with the PC as it boots up. Alternatively, with a USB sound card, it's not actually initialized until your already in windows, meaning the sound from before windows boots has no effect on the USB while it does on the dedicated sound card.
You could hook up a manually switch inline with your amps. Then just turn them off when you get out of the car and back on once your PC is booted.
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Comps, 2 x 12" Pioneer 305DVC, Visonik V500HC
ronjon228 is offline   Reply With Quote
Old 03-30-2008, 11:44 AM   #3
My Photos: (0)
I realize that, but I don't have the problem on my home PC with the same card so there has got to be something else I am missing.
Old 03-30-2008, 02:47 PM   #4
ronjon228's Avatar
My Photos: (0)
Well, you're not missing anything really. More like adding a bunch.
A car environment is completely different from a home PC. You introduce infinitely more interference in an automobile. Also, most of the time your using amplifiers to power your CarPC which introduces a whole lot of issues by itself. The noise, I'm assuming, is coming from your amps being turned on WHILE the computer is booting. Then, as the computer is booting it, and other components, are producing electronic interference during this. Your amps (and/or signal wires) are picking this up and displaying is as audio "noise".
You can check to make sure your not getting a ground loop anywhere. Also, check your RCA's and especially if your using 3.5mm to RCA cables, try moving the 3.5mm plug around a bit. I know that sounds pointless, but in many cases it can quiet down the noises.
After that, your only real option is to have a delay or manually switch to turn on/off the amp(s). In some cases, noise simply can't be eliminated by normal means.
CarPC:
Sound System:
Old 04-12-2008, 03:08 AM   #5
crooper's CarPC Specs
crooper's Avatar
My Photos: (0)
My X-Fi does the same thing. I'm not too worried about it.
As for the amp delay, this is the best thing out there. Works for lots of people, I haven't done it mostly because I'm lazy.
http://www.mp3car.com/vbulletin/soft...r-powerup.html
crooper is offline   Reply With Quote
Old 04-20-2008, 09:43 AM   #6
scfountain's CarPC Specs
scfountain's Avatar
Vehicle: 2004 Dodge 3500 Laramie, 4X4, Quad Cab, SRW, Cummins
My Photos: (0)
My X-FI doesn't do this. How do you have the sound card hooked to the amps?
Don't hold your farts in! They travel up your spine, into your brain, and that's where you get crappy ideas from!!!
scfountain is offline   Reply With Quote
Old 04-20-2008, 09:47 AM   #7
danielkh's CarPC Specs
danielkh's Avatar
Vehicle: 2004 Nissan 350Z
My Photos: (0)
Here is another option if that one doesn't work. This one, along with "hibernate trigger" works perfect for me.
http://www.mp3car.com/vbulletin/car-...-carputer.html
Has anyone tried using hibernate trigger to directly control a pci soundcard without using the serial DTR?
"Do not walk behind me, for I may not lead.
Do not walk ahead of me, for I may not follow.
Do not walk beside me either.
Just pretty much leave me the hell alone."
--unknown--
danielkh is offline   Reply With Quote
Old 04-20-2008, 10:42 AM   #8
My Photos: (0)
Just plugged straight on in, I wonder if the problem is the MB and not the X-FI.
Sponsored Links
vB code is On
Trackbacks are Off
Alternator Whine Only With Carputer tbird2340 Car Audio 25 06-29-2007 02:36 AM
Bloomin' alternator whine Vodkapete Car Audio 4 05-03-2007 05:25 PM
Got rid of BUZZ noise!! bleunetizen General Hardware Discussion 3 10-30-2005 07:20 PM
Troubleshooting: NOISE Red GTi VR6 Car Audio FAQ 0 03-26-2005 10:31 AM
Noise from PW-70a and not booting drib Power Supplies 5 09-24-2004 02:38 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
