The MP3car.com Store
Thread Tools Display Modes
Old 03-31-2008, 03:09 PM   #1
My Photos: (0)
Mid range full range and amp help please
Hey im kinda new to car audio...I want to put a new system in my car but need more info..What is the difference between mid range speakers and full range speakers? I saw some full range speakers online and they have like tweeters attached to them.does that mean i dont have to buy tweeters and is that the best way to go?
How do you match the speakers to your amps and connect them...is it the same as subwoofers?(parralel,series) I used some subwoofer diagram calculator to figure out for subs but they dont have any for tweeters and smaller speakers...please help
lloyd851704 is offline   Reply With Quote
Sponsored Links
Old 03-31-2008, 03:38 PM   #2
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
thread moved to car audio since this is a CarPC forum.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 03-31-2008, 07:37 PM   #3
NotYou's CarPC Specs
Vehicle: 99 Jeep Wrangler / 07 Grand Cherokee
My Photos: (10)
Take a look in the sticky at the top of this forum.. there's links to a LOT of online web sites that are more geared to general car audio installations. There's some info in here as well, but a lot of it has to do with interfacing car audio components to a carputer, not to general audio hardware.
As a quick helper on your questions...
Full range speakers are designed to reproduce the entire sound frequency of the music your playing. This is generally 20 - 20,000 Hz (and sometimes above), and is like an "all-in-one" type of speaker.
Mid range speakers are designed for.. well, the mid-range of sound. There is no set frequencies for this, but it generally rangesr from 1,000 Hz to 12,000 or 15,000 hz. This is where the "meat" of the music is. However, you still need something for the other frequencies or else the music sounds "empty" (subwoofers for lower frequencies, tweeters for high)
What you saw on those full range speakers is exactly that -- a tweeter. Full range speakers are more often then not mid-range speakers with a tweeter attached (there are exceptions, such as 3-way speakers)
Speakers are much simplier to connect then subwoofers, as 99% of the time they are wired into their own designated "port" on an amplifier. You either want a 4 channel amp, or two 2 channel amps. Each channel is one of your speaker locations (i.e. left front, or right front, etc).
This is just a quick start... there's lots of information on those links I referenced.
NotYou is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Speaker "Noise", Poor-quality Amp the cause of it? SuprchargdMazda Car Audio 15 07-06-2006 08:42 AM
Speakers/Amps for Range Rover - please dont flame RoyN Car Audio 20 01-09-2006 10:35 PM
Phoenix Gold 4 channel amp ummagawd Classified Archive 2 07-13-2005 06:40 PM
Bazooka 4 channel Amp tiggs Classified Archive 5 06-03-2005 10:52 PM
6 channel amp? auto_robotics Car Audio 4 11-24-2004 01:33 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
