Quote: Originally Posted by
mrcgibb
can i use a 4 channel amp (jl e4300) to drive 6 speakers? in my saab i have well 7 speakers if you include the centre one
but say 6 speakers just now , front dash and rear doors are mid range and tweeters ,
the front doors are bass
can u use the jl to power them , and if so how do i wire it ?
you probably could but it would require more information and the use of passive crossovers. to much trouble, time and money to achieve something that you'll probably only get 'satisfactory' results. Best bet; imho, is to purchase two sets of coaxial speakers, one for the front and one set for the rear and call it a day.
dLockers
i use a 2 channel amp to power 4 speakers, all through one channel.
only 300w - does the job fine imo.
that sounds like a horrible setup, you're essentially just running all that off of one chan? that means you're setting yourself back decades and just using mono sound
People spend a lot of time and money mastering cd's to take advantage of stereo sound and you're losing out on all that. what benefits are you getting by running all 4 speakers off of one chan? at the very least you should run two speakers off of each chan (left and right)
roflcopter
i'd assume you could run your front and rear outputs from your soundcard to a 4ch amp that that will take the front 1/2 and the rear on 3/4. then use a separate signal from the sub output to a 2ch amp and run the doors with a low pass filter at like 200hz and run the others with a hp at 200ish. or just run the front full range signals to all amps mentioned. but you wouldnt have fade control.
i may be misunderstanding you; but, It's a bad idea to run everything full range, a factory 3.5" speaker will probably only be able to handle 5 watts of power running full range. I wouldn't even consider running the factory 3.5" with anything below 200hz with even modest power.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
