Old 04-05-2008, 10:24 AM   #1
easy is an unknown quantity at this point
M-Audio Transit
Anyone using one for their Car PC Audio?
Seems a nice spec and its tiny.Was thinking I may use one for my Laptop Install...
Not sure the onboard soundmax audio will cut it!
Mobile 24-bit/96kHz USB audio
Specifications
line/mic in
dynamic range: 100dB (typical, -60dB input, A-weighted)
signal-to-noise ratio: 100dB (typical, A-weighted)
THD+n: 0.00316% (typical)
maximum input voltage: +6dBV
line out
dynamic range: 104dB (typical, -60dB input, A-weighted)
signal-to-noise ratio: 104dB (typical, A-weighted)
thd+n: 0.00316% (typical)
maximum output voltage: 0dBV
size/weight: 2-1/4” X 3-5/8” X 1”; 0.1 lbs.
easy is offline   Reply With Quote
Old 04-05-2008, 11:13 PM   #2
ArcaneDreams is an unknown quantity at this point
Well it would be ok as long as your amplifier has an optical input. If not, then you will have a max of 2 channels to work with.
ArcaneDreams is offline   Reply With Quote
Old 04-06-2008, 05:40 AM   #3
ptk
ptk is on a distinguished road
I have it. It's a bit of pain setting up the SPDIF pass-thru for Dorby and DTS streams. Also it's USB 1.1, there is some speed issues.
CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
ptk is offline   Reply With Quote
Old 04-06-2008, 12:59 PM   #4
Really?
Outputting from car audio head unit to home theater receiver mach5 General MP3Car Discussion 9 05-31-2007 12:20 PM
2005 BMW E46 CarX audio hook-up question? reggs Hardware Development 0 09-24-2005 04:06 PM
CarPC audio problems aal2000 Car Audio 2 09-07-2005 09:40 PM
Carputer integration with HUGE car audio system, help please septicdeath Newbie 19 12-04-2004 06:37 PM
Seperate VGA and S-Video with Audio Fox_Mulder General Hardware Discussion 7 07-01-2004 02:44 AM
