The MP3car.com Store
Thread Tools Display Modes
Old 04-09-2008, 09:06 PM   #1
My Photos: (0)
Red face amp problem
well it's not really a problem, but more of a question that should be in the newb section but i thought i'd give this area a try first. i want to power my 2 door speakers and one sub from a blaupunkt amp that put out 1000 watts max and 500rms in 2 ohm... how do i get my amp to put out 2 ohms to everything?
Dsmoov is offline   Reply With Quote
Sponsored Links
Old 04-09-2008, 09:35 PM   #2
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
if you want your amp to output it's 2-ohm rated output levels, then it has to see a 2-ohm load from the speakers. if your speakers and sub are 4-ohms each, then your amp will see a 4-ohm load per channel, and will output it's rated 4-ohm output level.
to bring the speaker impedance up or down, you need to hook up more than one speaker per channel (or replace the speakers with 2-ohm models). if you wire two speakers in parallel the impedance will be cut in half, if you wire two speakers in series the impedance will double.
assuming your two door speakers and subwoofer are all 4-ohms each, there is no way to get a 2-ohm load without adding more speakers or replacing them with 2-ohm speakers. (don't even try to hook your door speakers and subwoofer to the same channel[s]).
what are your door speakers impedance? what is your subwoofer impedance? how many channels is your amp?
FusionFanatic is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
What's wrong with my Amp? joseph5458 Car Audio 14 12-03-2007 08:37 AM
2 to 1 amp problem lexdiamond20 Car Audio 2 07-02-2007 03:50 PM
Could my amp be bad or did i miss something? sansoo24 Car Audio 20 03-05-2007 01:45 AM
power to amp problem djXternal Car Audio 5 06-01-2005 09:39 PM
Sponsored Links
Ad Management by RedTyger
