Old 04-15-2008, 05:49 AM   #1
bes51659's Avatar
bes51659 is on a distinguished road
Line-in (HQCT tuner), Mic, and PC Audio out
I want to use microphone for voice input and line-in for radio (HQCT). My soundcard SB live has got microphone and line input, but there is a switch in the mic jack, so line-in can only be used if there is no microphone connected!
-- question 1 -- So I need an extra input for the mic. Can I add a soundcard, or maybe configure the PC to use its internal mic input?
Apart from this I am very happy with my SB live. It contains equalizer and sub output that fits my 2.1 system. (At least I think so at this moment) It also contains noice generator that will be a great tool for measuring frequency curve. I would like to get a flat curve with eq and then use bass and treble control, and maybe loudness.
-- question 2 -- Have you guys a recommendations in what measuring mic and sw to use?
-- question 3 -- What about more simple bass/treble type of filter. Any suggestions?
-- question 4 -- What do you think about letting SB live handle sub out? good enough, or should I use the poweramps filters?
General points? What do you think?
help much appreciated
bes51659 is offline   Reply With Quote
Old 04-17-2008, 11:05 AM   #2
bes51659's Avatar
Well, I've found that the onboard audio is much better suited for my needs. It can mix microphone, line-in (tuner) as well as wave (pc).
Audio quality should be good enough. It's applies to Microsoft WHQL/WLP 2.0 audio requirements and has 100dB S/N.
Its a RealTek device.
My mobo is the Commell LV-679
My questions are:
- how does the sub support work? I have not found a way to set turn-over frequencies. Maybe because I have not connected a sub yet...
- Can plug-in equalizer be used?
- Can the mixer/eq be controlled from sw?
Thoughts?
Exists PC Bluetooth Phone Dialing / Bluetooth FM Radio Tuner mrcool2k Bluetooth Hardware 3 03-06-2008 11:58 AM
Wireless Mic solution for PC? Nola111 Wireless Communications 16 06-25-2007 08:26 PM
Anyone use a bluetooth headset as their PC Mic? tbird2340 Wireless Communications 11 04-01-2006 02:33 PM
Car PC Audio Design sza Car Audio 4 10-27-2004 10:08 AM
