The MP3car.com Store
Thread Tools Display Modes
Old 04-17-2008, 03:10 PM   #1
Vehicle: 1998/Pontiac/Trans Am
My Photos: (0)
Components not working...please help?
i have recently put in a pc and so had to add 2 4channel amps to supply power for my components. To speeding things up and recude the amount of tearing apart of my car i decided to wire the front and rear, but not the center, speakers through the factory wires. All i did was take some nice 12ga or so copper wire and splice it to the wiring harness adapter i got from Bestbuy a few years ago, i then ran the other end of this cable bundle to the amps. I worked of a while but now i am getting almost nothing to these 4 speaker sets(each set is a seperate mid and tweeter). I get only a small weak signal from the tweeters? the car is a 98 Trans Am.......any idea what is happening? Or how i can fix this problem? The amp and all RCA cables have all been tested and are working well.
solo44 is offline   Reply With Quote
Sponsored Links
Old 04-17-2008, 09:26 PM   #2
boomintrac's CarPC Specs
boomintrac's Avatar
Vehicle: A little white wagon
My Photos: (0)
Check the sound card settings, somethings might have gotten switched, or volume attenuated accidently.
Aron
trukz
boomintrac is offline   Reply With Quote
Old 04-20-2008, 09:34 AM   #3
scfountain's CarPC Specs
scfountain's Avatar
Vehicle: 2004 Dodge 3500 Laramie, 4X4, Quad Cab, SRW, Cummins
My Photos: (0)
Have you checked to see if your car has a factory amp? I have a friend with a 1999 Trans AM WS6 and it had a factory amp. If so, you'll need to bypass it in order to use an aftermarket amp.
Don't hold your farts in! They travel up your spine, into your brain, and that's where you get crappy ideas from!!!
scfountain is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Infill G4 stopped working haiminger Centrafuse 12 11-11-2007 02:54 PM
No USB Devices Working Out of the Blue tbird2340 General MP3Car Discussion 6 10-17-2007 11:21 AM
-DisableWindowHooks not working - 1.1.0.0 Indy StreetDeck Bug Reports 3 07-31-2007 08:40 AM
SPV M700 / HTC P3600 not working with Phonecontrol Tracert PhoneControl 0 07-13-2007 10:16 PM
Anyone currently working with 18f2550 lez General Hardware Discussion 17 11-03-2006 07:44 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
