Hey Recoil,
I read your post and at first said "I don't want to touch this one- could be too messy."
But not replying or trying to be of assistance is the easy way out...
As a long-time electronic tech and electronic hobbyist, I have been taught that toubleshooting, isolating the problem is the heart to fixing things, and often the hardest part. It comes down to eliminating possibilities.
So, here we have a car electrical system, a carpc with dc/dc supply connected, and audio ouput of carpc connected to amplifier(s), right?
I had a little trouble reading/understanding your post, but I noticed that you said GLI actually made the problem worse. Sure sounds like you've got a ground loop, though.
I wonder if you have the ground correct on the mobo, or maybe you have grounded too many points on the mobo, and thus created a ground loop.
First, can you power your carpc with some other 12v source such as power supply or battery fro other vehicle. Then, when you run the carpc connected to your audio amp(s), you can see if the noize is still there.
Do you have carpc connected to more than one amplifier? Can you just connect it to one amp or switch between amps to try and isolate the noisemaker?
Hmmm, could the noise be induced noise do=ue to your mobo not being in a case?
I sure wish that I could see the unit. Seeing yields so many more clues. Any carpc fanatics in your town?
Parting shot: pull all wiring off, and reinstall one by one, making sure they all go where they should. Also, I personally ran a 12v ground cable from batt to chasis, and grounded all amps, carpc stuff to that very same exact point, to hopefully eliminate circulating currents.
Best of luck and blessings.
Happy CarPC'ing!
