Old 04-20-2008, 12:05 AM   #1
purpra is an unknown quantity at this point
When arming the alarm the radio drains the battery
Recently my VW GTI 2002 VR6 would not start after the car sitting for two days - battery would drain.
I discovered that there was a draw of 140 mAmp when the car alarm is armed (did this test by putting an amp-meter in-line between the negative battery post and the battery cable).
I started taking one fuse at a time and found that fuse 42 was doing the draw excesive. Fuse 42 is for the Monsoon radio (8 speakers and amplifier with one CD changer and tape, AM/FM).
When pulling fuse 42 out the reading would drop to 50 mAmp. Is this normal for VW GTI 2002 VR6 2.8?
When fuse 42 is in, the radio works fine however the two symptoms I found are the following:
1. When the car alarms is armed then there is a parasitic draw of 140 mAmp
2. When I remove the negative cable from the battery post the radio does not go into SAFE mode when I reconnect the battery cable to the battery post. I believe this is normal. According to another post this is normal since the radio has not been move to another car - right?
Anyway, it is pretty sad I have to drive without radio (fuse 42 out) to avoid the parasitic draw while the car is sitting with the alarm armed. The worse part is that everything in the radio works great when putting the fuse 42 back in.
The dealer said that I have to replace the radio and that will fix the issue however what if there is something wrong with the alarm since this drawing occurs when the alarm is armed.
Any help will be greatly appreciated
purpra is offline   Reply With Quote
Old 04-20-2008, 01:36 AM   #2
boomintrac's Avatar
boomintrac will become famous soon enoughboomintrac will become famous soon enough
You will probably get better results from a dedicated stereo forum with an alarm subtopic.
Is the alarm factory or aftermarket?
Aron
Zapco DSP-6
Zapco 500.1-Midbass-X2
Zapco 360.4-Midrange
Zapco 360.4-Tweeters
Zapco 500.1-Sub
boomintrac is offline   Reply With Quote
Old 04-20-2008, 01:41 AM   #3
Everything is OEM...
Old 04-20-2008, 01:43 AM   #4
Oh, I have also posted this topic in VWvortex. I am willing to go back to the dealer and pay the $460 they are asking to replace the radio however it would be real sad that it is actually the alarm or the amp or some wiring issue between the radio and and the speakers... or perhaps the relay that it in between the battery and fuse 42.
Thanks for the suggestion
Can I put an extra battery in my Chevy? Mastiff Power Supplies 14 11-04-2008 12:45 PM
How do I setup my Radio or Sat Tuner ? Which tunners work ? guino RR FAQ 0 03-20-2005 02:34 PM
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 10:31 PM
Really cool alarm system using Basic stamp lstrunk General Hardware Discussion 14 06-13-2002 08:08 PM
Sproggy drains the hell outta my battery SuperMatty Power Supplies 8 03-11-2002 05:51 PM
