Old 04-21-2008, 09:40 AM   #1
AustinMatherne is an unknown quantity at this point
Amp for Scion tC Carputer
I'm looking for a somewhat affordable amp for my 05 Scion tC (stock speakers).
To be completely honest, I don't know that much about amps, speakers, or sound in general, and I don't really want to learn (I'm aware this might get me flamed)...
I basically just want to hook up my carputer (the computer is using a Sound Blaster Audigy SE sound card), to the stock speakers in my 05 Scion tC, without degrading the sound quality compared to my stock head unit (and not losing volume).
I realize I could just buy another head unit with an auxiliary input, but I don't feel that would be a very elegant solution.
~ Austin
P.S. I'm open to buying a used Amp.
AustinMatherne is offline   Reply With Quote
Old 04-21-2008, 03:54 PM   #2
XC-C30's Avatar
XC-C30 is on a distinguished road
Quick learner ey
Don't think anyone is willing to spoonfeed, or help, for that matter. Especially if you just admitted you aren't at all willing to do an effort yourself.
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 04-21-2008, 05:14 PM   #3
I'm not looking to be spooned (I'm capable of searching on my own).
All I'm looking for is a suggestion on an affordable Amp that will work with my current setup.
The reason I don't really want to learn about speakers and so forth, isn't because I don't want to do the work, it's because I know if I do then I'm gonna want to replace the speakers add a sub, etc, etc, etc and I don't have the money to do it. So why torture myself?
I hope you understand,
~ Austin
Edit: I'm familiar with the Sonic T-Amp (looked into it for my desktop back when it first came out) and I've seen some people talk about it around here (by searching). I know its only 15 watts, isn't that not nearly enough for a car setup?
Thanks,
~ Austin
Old 04-21-2008, 06:13 PM   #4
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
i always suggest the t-amp if you want it in a small space and don't want to have to worry about running new wiring. i believe that it'll give you near stock sound. your stock head unit probably is only putting out about 8 watts rms anyways.
if you dont mind running the wires and everything look at the infinity/jbl amps, they are pretty well made and inexpensive. should give you plenty of headroom so make sure to set your gains correctly.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 04-21-2008, 06:16 PM   #5
skuller is an unknown quantity at this point
soundstrom 4f400.
4 channel, about $50 dollar at amazon.
working great on my stock speaker setup (at least better then the output of my stock head unit)
skuller is offline   Reply With Quote
Old 04-21-2008, 06:19 PM   #6
This was exactly the kind of reply I was looking for.
I'm surprised the head unit only puts out that many watts.
Space is very minimal for this install so I'll look more into the T-Amp (but I'll give the infinity/jbl a look to).
Thank you,
~ Austin
Edit: So you're saying I can just hook the Amps up to the speaker wiring running from the stock head unit?
Am I correct in assuming I need two T-Amps 2x2 Channels = 4 Channels? and that I'll just use an adapter that will split the rear output from my sound card into two channels and I do the same with the front output?
Also, does it matter what channels are running on the Amps? For instance both front channels on one Amp and the rear on the other, or left and right?
Is the following digram correct?
Thanks again,
~ Ausitn
Old 04-21-2008, 07:35 PM   #7
MySQL Error
scott_fx's Avatar
you could also try two of these if you have enough power on your psu (or maybe get a second dc-dc psu):
http://cgi.ebay.com/2-15-watt-4ohm-T...QQcmdZViewItem
actually... you would run into similar powering issues regardless of which amp you used. you can just hook these amps straight to the 12v car battery.
M10k
My Car Pc Install
Old 04-21-2008, 08:05 PM   #8
Are you sure I cant run the two T-Amps off my OPUS 320W PSU?
I'll be using the 320W OPUS to power the following system.
Motherboard: DFI nForce4 Ultra-D
Processor: Underclocked AMD Opteron 165
Video Card: XFX GeForce 7100GS
Sound Card: Sound Blaster Audigy SE
Hard Drive: Seagate 300GB 7200.8 IDE
Display: MP3Car 2008 7” Transflective
GPS: USGlobalSat BU-353
USB Bluetooth Adapter: D-Link DBT-120
USB Wi-Fi Adapter: D-Link DWA-556
Microphone: Andrea Electronic Superbeam
~ Austin
Old 04-21-2008, 08:24 PM   #9
MySQL Error
scott_fx's Avatar
you very well could, just make sure. I'll let you do the legwork on that :-)
~ Austin
M10k
My Car Pc Install
Old 04-21-2008, 08:29 PM   #10
I can do that.
Just to clarify, all I need for the Amps (besides running power to them) would be two (in the right length)
3.5mm Mini-Stereo Male to Two RCA Male Speaker Cable
Thanks again for all your help,
~ Austin
Old 04-21-2008, 08:45 PM   #11
MySQL Error
scott_fx's Avatar
depend on which amp you go with. if you go with the SI amp then you would just need a 3.5mm mini to 3.5mm mini. if you go with the other amp i linked too you could use a pair of these:
Highslide JS
or just get a single 3.5mm mini to 3.5mm mini, cut it in half and just use the screw down terminals on the board
M10k
My Car Pc Install
Old 04-21-2008, 08:55 PM   #12
If there's not that big of a difference between the SI and the amp you linked to then I'll go with the one you linked to.
How do they compare?
~ Austin
Old 04-21-2008, 09:19 PM   #13
MySQL Error
scott_fx's Avatar
dunno, only listened to one. one is half the price though :-)
M10k
My Car Pc Install
Old 04-21-2008, 10:57 PM   #14
I'm going to go with the SI as I found a couple of the 2nd gen SI's used for $30.
Again, I want to thank you for everything,
~ Austin
Old 04-23-2008, 04:33 AM   #15
So, any idea how (or where I could find out how) to wire the T-Amps to my OPUS 320 Watt PSU?
Thanks,
~ Austin
Two audio outputs simultaneously into one amp input - possible? l2r99gst Car Audio 20 03-19-2006 05:01 AM
Who is using their carputer straight to an amp? verbal kent Car Audio 38 02-11-2006 11:30 PM
Questions re: my Carputer amp, EVIC, etc. vettejock99 Car Audio 2 09-07-2005 04:39 PM
sound quality between carputer going through the HU and carputer going to amp lookinco Car Audio 9 08-07-2005 12:27 PM
seperate amp for carputer schrodos General Hardware Discussion 2 11-12-2000 10:00 PM
