The MP3car.com Store
Thread Tools Display Modes
Old 04-21-2008, 08:53 PM   #1
My Photos: (0)
CarPC to Amp connection. How to make preamp levels?
I am planning out my car computer, and would like to do it without using a headunit, just to keep things as simple as possible.
I have done a lot of searching, but haven't found the specific answer I'm looking for. (probably because I don't know the specific terms to use in this case)
To connect a computer to an amp, what do I need to do to bring the inputs to a preamp level?
I found several posts mentioning a DSP, but that's it. I want to use a small case, without a full size sound card. What are my options?
component is offline   Reply With Quote
Sponsored Links
Old 04-21-2008, 10:05 PM   #2
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
your soundcard outputs at preamp level all you need is a cable that plugs into your soundcard (3.5mm mini usually) and then the other end will plug into your amp (rca usually)
it's in the faq btw :-)
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 04-21-2008, 10:16 PM   #3
JimmyFitz's CarPC Specs
JimmyFitz's Avatar
Vehicle: 2002 Thunderbird V8
My Photos: (0)
FAQ
You can use on board sound output from the mobo. This FAQ shows how to hook it up:
http://www.mp3car.com/vbulletin/advf...iew&advfaqid=7
Here is a tiny USB sound device:
http://store.mp3car.com/Turtle_Beach..._p/com-019.htm
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 04-22-2008, 12:58 AM   #4
My Photos: (0)
Thanks, thats exactly what I was looking for.
Sponsored Links
vB code is On
Trackbacks are Off
Please advice on weird headunit to amp ? mrcgibb Car Audio 4 03-16-2008 04:29 PM
V-dub monsoon amp input wiring help for carPC jstick81 Car Audio 2 01-17-2008 04:51 PM
Wiring CarPC from Amp wiring? Calipso Newbie 6 02-03-2007 05:32 PM
anyone can teach me how to make a CARPC? chaolanren Newbie 8 04-08-2005 01:19 AM
about to make my first CarPC Eclipse-GST Newbie 5 02-10-2005 04:52 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
