Old 04-21-2008, 09:53 PM   #1
component is an unknown quantity at this point
CarPC to Amp connection. How to make preamp levels?
I am planning out my car computer, and would like to do it without using a headunit, just to keep things as simple as possible.
I have done a lot of searching, but haven't found the specific answer I'm looking for. (probably because I don't know the specific terms to use in this case)
To connect a computer to an amp, what do I need to do to bring the inputs to a preamp level?
I found several posts mentioning a DSP, but that's it. I want to use a small case, without a full size sound card. What are my options?
component is offline   Reply With Quote
Old 04-21-2008, 11:05 PM   #2
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
your soundcard outputs at preamp level all you need is a cable that plugs into your soundcard (3.5mm mini usually) and then the other end will plug into your amp (rca usually)
it's in the faq btw :-)
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 04-21-2008, 11:16 PM   #3
JimmyFitz's Avatar
JimmyFitz is on a distinguished road
FAQ
You can use on board sound output from the mobo. This FAQ shows how to hook it up:
http://www.mp3car.com/vbulletin/advf...iew&advfaqid=7
Here is a tiny USB sound device:
http://store.mp3car.com/Turtle_Beach..._p/com-019.htm
2005 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 04-22-2008, 01:58 AM   #4
Thanks, thats exactly what I was looking for.
Old 08-30-2008, 08:28 PM   #5
srtbrian is an unknown quantity at this point
Will all CarPCs that say Audio like this one http://www.mitxpc.com/proddetail.asp?prod=CPCI16VOOM2 have onboard Audio and can I hook up a 4CH amp and a Mono Amp for my sub?? and have 5.1 Sound? How do I know what place on the rear to hook the 1/8" jacks into? Sorry for the newbe question just need to know.
srtbrian is offline   Reply With Quote
Old 08-30-2008, 10:41 PM   #6
digitalmayhem is an unknown quantity at this point
5.1 is 5 channels plus a sub no? you would have 4.1 right?
digitalmayhem is offline   Reply With Quote
Old 08-31-2008, 12:51 AM   #7
I have 6 Speakers for my mids but Im useing a 4CH amp and my dash 3" im hooking into one CH. and then A sub on its own Amp. I think a USB sound card would be best but cant get any good ideas from searching on what everyone is having good luck with
Old 09-12-2008, 02:15 PM   #8
trextegra is an unknown quantity at this point
i am still in the planning stages of my system and i also want to run without a headunit. computer straight to the amp.. i found this during my research but havent tested it or anything but specs look amasing. http://www.sonicelectronix.com/item_...on+EQS746.html altho this basically takes the place of a headunit it is much cheaper and perfect for what you want to do. i am planning on using the stock mobo sound run 1/8 to rca adapter to this crossover. the crossover then divides the signal into 6 channels front l/r rear l/r and subwoofer it has a 7 band equilizer which should provide plenty of tuning. a fader note you control left to right from computer volume control sub control plus an aux input for ipod or game system. the greatest feature of all that i love is the 7volt preamps it has cant be beatin... the only problem you face with this is were to mount..
trextegra is offline   Reply With Quote
Please advice on weird headunit to amp ? mrcgibb Car Audio 4 03-16-2008 05:29 PM
V-dub monsoon amp input wiring help for carPC jstick81 Car Audio 2 01-17-2008 05:51 PM
Wiring CarPC from Amp wiring? Calipso Newbie 6 02-03-2007 06:32 PM
anyone can teach me how to make a CARPC? chaolanren Newbie 8 04-08-2005 02:19 AM
about to make my first CarPC Eclipse-GST Newbie 5 02-10-2005 05:52 PM
