The MP3car.com Store
Thread Tools Display Modes
Old 04-25-2008, 10:11 AM   #1
Phatsacks's CarPC Specs
Phatsacks's Avatar
Vehicle: 2007 Corolla S
My Photos: (0)
Ground loop isolator, isolated half my audio?
So I get a whine, it's not terribly loud, and with my music at a decent level I can't hear it.
However, if I'm not listening to music, but say navigation directions, or a road trip and someone isn't blasting a DVD, then you hear it.
So I had the install shop throw on a ground loop isolator. No more whine! Half the sound gone =(
So we had to remove it. Do you think it was a bad isolator? Are some isolators better? Any other solution, other than trying different locations for the ground?
It's not terrible, but it's annoying if I'm wanting to use the navigation
Phatsacks is offline   Reply With Quote
Sponsored Links
Old 04-25-2008, 10:38 AM   #2
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (129)
some are DEFINITELY better than others.. i bought a scosche one from walmart a couple days ago and it made the sound twice as loud as it was before the isolator was installed so i took that crap back lol
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 04-25-2008, 10:55 AM   #3
Phatsacks's Avatar
My Photos: (0)
Well if anyone has one that works well, please post so myself (and maybe others) can try it out.
Thanks!
Old 04-25-2008, 01:46 PM   #4
Nola111's CarPC Specs
Nola111's Avatar
Vehicle: 2006 VW Passat 2.0t
My Photos: (1)
I read somewhere very recently that the one that the Best Buy install shop sells is very good and is the most transparent one they know of.
Nola111 is offline   Reply With Quote
Old 04-25-2008, 02:21 PM   #5
rgarjr's CarPC Specs
rgarjr's Avatar
Vehicle: 98 Lexus GS300
My Photos: (37)
I bought that one from BestBuy and it really didn't help out much on my setup.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 04-25-2008, 03:06 PM   #6
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
I had 2 laying around from RadioShack from when I worked there, and they worked pretty well. When I moved my PC I was more careful with the wiring and didnt need them anymore...
Old 04-25-2008, 09:33 PM   #7
brucedog's CarPC Specs
brucedog's Avatar
Vehicle: 2000 Saturn LW Wagon
My Photos: (22)
I, too, purchased the Radio Shack GLI (about$17) and noize went bye-bye.
I have a discriminating ear and the GLI did not degrade sound quality one bit.
Best of luck and blessings.
Happy CarPC'ing!
brucedog is offline   Reply With Quote
Old 04-26-2008, 04:20 PM   #8
Vehicle: 2001 Audi TT Quattro Coupe
My Photos: (0)
The RadioShack GLI I bought made my sound HORRIBLE. Low frequencies were muddy/non-existent, vocals were lost in the jumbles of high frequencies... horrible. I thought it was my BlitzSafe adaptor the whole time, even had it replaced under warranty and the same result. I took out the GLI today and it's back to perfect sound quality - looks like I don't even need the GLI anyways, I have no background noise from the car/alternator.
TTeuer is offline   Reply With Quote
Old 04-26-2008, 04:43 PM   #9
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
Has anyone considered the output impedance of the circuit driving the GLI? Consider the high pass RL filter on this page : http://www.play-hookey.com/ac_theory...s_filters.html
Personally I use a unity gain opamp "buffer" to reduce the output impedance to drive my GLI, I get no issues.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Eliminating Ground Loop norbie Car Audio 32 08-11-2006 12:56 AM
ground loop problem... cant fix it okeydokey Car Audio 9 06-23-2006 08:27 AM
Turtle Beach Santa Cruz Sound Card GIVES me a ground loop? rmjjensen General Hardware Discussion 2 11-15-2003 07:26 AM
How exactly do you ground the audio wire? SuperAJ General Hardware Discussion 7 01-03-2003 08:46 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
