The MP3car.com Store
Thread Tools Display Modes
Old 04-29-2008, 12:40 AM   #1
My Photos: (0)
protect light is on my amp
i need help... i have a 300 watt Jensen amp and 2 12in insignia subs. my amp was workin good for about 1 week and then me and my bro hooked up a kenwood 600 watt amp to them to see if it would work. but when we hooked my old amp back up the protect light was on. i was wonderin if anyone has any suggestions, i would really appreciate it.
rocko22 is offline   Reply With Quote
Sponsored Links
Old 04-29-2008, 01:51 AM   #2
dMand's CarPC Specs
My Photos: (2)
open your speaker box, check all the wires to see if the positive and negative wires have somehow come in contact causing your amps circuit protection to light up.
dMand is offline   Reply With Quote
Old 04-29-2008, 02:18 AM   #3
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
sounds like an impedance problem. how did you wire the two subs to the amp?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 04-29-2008, 05:53 AM   #4
My Photos: (0)
they are unbrigded right now. I had them brigded when it was working properly.
Old 04-29-2008, 05:17 PM   #5
MySQL Error
scott_fx's Avatar
My Photos: (0)
we need to know more. specs on the amp, specs on the sub (voice coil amount and impedance)
M10k
My Car Pc Install
Old 04-30-2008, 11:30 AM   #6
My Photos: (0)
Key Features (AMP)
Amplifier Type: Dual Channel
Bass Boost With Bass Boost
Bridgable
Power Output:
RMS Power at 4 Ohms75 W x 2
RMS Power at 2 Ohms100 W x 2
Performance:
Bass Boost Frequency = 45 Hz
Other Features
MOSFET amp Yes
subs are 12in 400 watts 200 RMS
Old 05-04-2008, 10:39 AM   #7
pancit175's CarPC Specs
Vehicle: 96 Talon
My Photos: (0)
There are only 2 possibilites: wiring issue or equiptment failure.
If you have a meter check the impedances of the speakers that they are correct and not shorting out.
Did you accidentally wire in the power wires incorrectly or backwards at any pont when you were reinstalling the amp? Doing that on some amps, even for a sec, can destroy a good working amp.
" In the beginners mind there are many possibilities, but in the experts mind there are few. "- Shunryu Suzuki
PROGRESS:
[DONE&DONE] (Considering a redesign)
pancit175 is offline   Reply With Quote
Old 05-04-2008, 12:00 PM   #8
labenedict's CarPC Specs
Vehicle: 2003 Hyundai Sonata
My Photos: (0)
Simply put, I had this issue when the positive and negative wires on one of my speakers touched each other. What happened was that somehow I broke the thing on the speaker that holds the two terminals for the speaker wire.
I'd try disconnecting each speaker wire from the amp, one at a time, and by process of elimination, see which speaker is causing the protect light to come on and then start by checking the connection to that speaker and follow the wire back to where it connects to the amp looking for problems with that wire.
labenedict is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Unusual amp shut off problem....please help! mike40370 Car Audio 12 12-05-2007 04:13 PM
Can I run this amp with this sub, how do ohms work, help/recommendations... mikeym Car Audio 37 02-12-2007 11:10 AM
Amp running hot...?? Emerica2843 General Hardware Discussion 5 02-08-2006 05:40 PM
Amp running hot...?? Emerica2843 Car Audio 6 01-29-2006 07:29 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
