The MP3car.com Store
Thread Tools Display Modes
Old 05-03-2008, 11:47 AM   #1
My Photos: (0)
Volume control knobs
Hi all...I'm installing a car stereo in my shop because of its small footprint. I also want to hook up two speakers inside and two outside each pair with its own volume control. That way the head unit volume acts as master and then I can control the speakers individually.
My challenge has been in finding reasonably sized controls. All I could find are these huge in-wall controls made for home theaters. There's got to be something smaller out there. Any help is greatly appreciated.
Sam
ognat42 is offline   Reply With Quote
Sponsored Links
Old 05-03-2008, 12:53 PM   #2
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
Sam
how much are you willing to spend? you could use an l-pad or a twistedpear audio stepped attenuator
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 05-04-2008, 10:00 AM   #3
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
http://www.mp3car.com/vbulletin/1076188-post5.html
^^That will work if have amplifiers, but if you are going through the headunit amplifier there are controls called fader.
durwood is offline   Reply With Quote
Old 05-04-2008, 12:27 PM   #4
My Photos: (0)
thank you all for the replies. I'm not looking at spending a small fortune but within a $100 is acceptable. Wasn't planning on installing amplifiers, nor did I want to do any soldering . I'll search for the faders. They seem to be just what I want.
Old 05-05-2008, 09:39 AM   #5
My Photos: (0)
I would not recommend using an in-wall type attenuator.
There are 2 reasons: (without going deep in technical crap)
1. Car stereo gear is simply not robust enough to handle the continuous use when feeding a resistive load.
2. Most inwall VCs have a shared ground path, most car stereos have to be 100% isolated.
If size is the only criteria, you might want to find a good brand name micro system. It is going to way more stable, have a decent remote, likely better sound, deal just fine with inwall VCs, easy to add subwoofers should you get the urge, etc...
HTH!
Luke
StereoInstaller is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Change behaviour Volume control DbXL Centrafuse 0 07-09-2006 11:09 AM
Roadie Volume Control tjp12100 FrodoPlayer 0 06-21-2006 03:30 PM
External volume control, knob, powermate, or something else? stimps Input Devices 3 12-10-2005 01:12 AM
Volume control in Xenarc 700TSV BMW-7 LCD/Display 3 04-06-2005 11:08 PM
hardware volume control ODYSSEY General Hardware Discussion 18 04-20-2001 10:43 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
