The MP3car.com Store
Thread Tools Display Modes
Old 05-07-2008, 07:44 AM   #1
My Photos: (0)
Alpine PXA-701 / 700: DIY remote control & PC control
Just an early post to share some work on remote controlling the PXA-70x Multimedia controllers.
Target
For my new install, I have been looking at no headunit. Like many, this has led me down the PC optical > Alpine PXA700 route.
I am also looking to limit the amount of boxes/displays/controllers to a minimum, especially 3rd party, on show.
The RUX controller is therefore being altered to be a "display" only device, within an overhead console. The display will be behind a tinted screen, and will help maintain the "factory look".
Remote controlling
For some time, I was going to "hardwire" the micro switches of the RUX PCB. This would create a lot of wiring within a tight space however.
Time for some good news:
The RUX does not work on a single data bus i.e. every function (display and switches) working off an unknown word protocol. Instead, the RUX uses basic resistor ladders.
This explains why the unit uses a 13 pin connector. As you can all see, this creates opportunities!!
Ideas for implementation
I'm currently working on the following ideas:
1) Build a "passthrough box". This would connect to the PXA and the RUX.
2) Add additional switch panels. Using an exact replica of the resistor ladders, I shall add a couple of switch panels. (My T5 Caravelle has three rows of seats and 2 displays). As these switches are ladders in parallel, there is no real limit. Not all boxes need be the same of course. I'm looking to have 1*full controller for programming, and 1 / 2 "lite" boxes for typical "user" operation.
3) I shall also remote control these switches for PC control. I'm going to do this by using optocouplers controlled by a Phidgets USB device and girder.
PC control will allow some user friendly displays of my 6* user presets - displaying the settings and intended uses - music, movies, driver only, centre screen time alignments etc
Needless to say, you could also make an IR version...
Encoder
More work to do on this. Encoders don't like parallel operation typically.
I have limited time (don't we all) - so may not be able to do much more than share the idea and circuit diagram for now - but will obviously try...
Tony G is offline   Reply With Quote
Sponsored Links
Old 05-07-2008, 09:11 AM   #2
_
RedGTiVR6's CarPC Specs
RedGTiVR6's Avatar
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
So this will all be software controllable?
The way I'm reading it, you're wanting to eliminate boxes....but to do that, you're adding boxes. The RUX is really very thin.
So you're essentially mounting the display of the RUX one place, then mounting the buttons elsewhere....correct?
Jan Bennett
Centrafuse Support
RedGTiVR6 is offline   Reply With Quote
Old 05-07-2008, 09:29 AM   #3
My Photos: (0)
Hi RedGTiVR6,
More boxes maybe - and you effectively spot an error in my thinking perhaps!
For clarity, I don't want an Alpine unit on view. I don't want buttons in my overhead install. What I want is a discreet interior, with a few buttons added in appropriate places - in the same style and illumination as VW.
Maybe one more box (the passthrough) but hidden..
Maybe sharing my idea on this forum was a bad one - I get really defensive at times like this
P.S. With optocouplers as switches, you can mimic a button push, and you can add graphics to the memories describing your settings.
Old 05-07-2008, 10:55 AM   #4
Raw Wave
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
I actually think this is a fantastic idea, the reason i ditched the h701 was because i hated the cluttered and space ship feel of the rux controller. if i could have gotten rid of that i would have kept the 701.
a few ideas, instead of using phidgets you could look into fusion brain and have the rux controlled via the computer.
if you want a more permanent display but hidden, you could get a piece of smoked plexi and get a vinyl cutter to cut out 'buttons' on black vinyl to which youd mount to the back of the plexi. then you backlight it with some leds and use the qprox ic's to create a touch sensitive panel
Quote: Originally Posted by Tony G View Post
Hi RedGTiVR6,
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 05-07-2008, 11:02 AM   #5
_
RedGTiVR6's Avatar
My Photos: (73)
if you can make the Alpine controllable by the computer, and even show the display via the computer, I'll buy one in a new york minute.
However, by it's nature, you need the display of the RUX to be visible, AT LEAST for tuning purposes. If you completely hide it, it's pretty much pointless.
Jan Bennett
Centrafuse Support
Old 05-07-2008, 09:20 PM   #6
Raw Wave
scott_fx's Avatar
My Photos: (0)
tuning and volume control. hell, if he could just figure out how to piggy back the volume control then the rux could be hidden
M10k
My Car Pc Install
Sponsored Links
vB code is On
Trackbacks are Off
How2 control CarPC from key fob.... NotchbackVW Power Supplies 1 09-21-2007 05:27 PM
XENARC 700 TSV Remote Control kbreeden LCD/Display 0 08-08-2005 09:18 AM
need alpine remote control snoop Classified Archive 1 08-25-2004 06:07 PM
home theater pc remote hoodlum General Hardware Discussion 15 04-05-2004 07:37 PM
One remote to control them all liquid_smoke Input Devices 5 01-22-2004 09:00 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
