The MP3car.com Store
Thread Tools Display Modes
Old 05-08-2008, 02:38 PM   #1
HNaga's CarPC Specs
My Photos: (0)
enhancing sound system
Hello:
I just installed some enhancement on my sound system.
Currently it is:
Rear speakers infinity 100 RMS
Front speakers Infinity Kappa 75 RMS
AMP JBL 60X4
I also ordered CTF700-H - VGA 7" TFT which will replace the sony HU.
what do you think?
HNaga is offline   Reply With Quote
Sponsored Links
Old 05-08-2008, 03:06 PM   #2
pancit175's CarPC Specs
Vehicle: 96 Talon
My Photos: (0)
I think, therefore I am.
Please be more specific with your line of questioning. Because everybody has different needs and perceptions, certain products and opinions may change in different situations.
"Now, the world don’t move to the beat of just one drum, What might be right for you, may not be right for some." - Different Strokes
" In the beginners mind there are many possibilities, but in the experts mind there are few. "- Shunryu Suzuki
PROGRESS:
[DONE&DONE] (Considering a redesign)
pancit175 is offline   Reply With Quote
Old 05-08-2008, 03:48 PM   #3
HNaga's CarPC Specs
My Photos: (0)
well , I mean , is it OK for moderate sound system? do I miss something?
are all componenets compatible with each other?
Old 05-08-2008, 03:59 PM   #4
rijndael's CarPC Specs
rijndael's Avatar
Vehicle: 2005 Honda Civic EX SE
My Photos: (0)
your amp is not going to be powerful enough to power your front and rear speakers...its only powerful enough to power your front while bridged into 2 channels...
Trouble deciding on car speakers? Clicky Clicky
My Myspace page (view my pics for carputer worklog)
Speakers: DLS Ultimate Iridium 6.3 Link
Subwoofer: TC-9 15"
Amplifier#1 (Front Stage): DLS Ultimate A4
Amplifier#2 (Sub) DLS Ultimate A6
rijndael is offline   Reply With Quote
Old 05-08-2008, 04:03 PM   #5
HNaga's CarPC Specs
My Photos: (0)
thanks for your reply , that what I need to know, what would be better for the amp?
Old 05-08-2008, 04:17 PM   #6
rijndael's Avatar
My Photos: (0)
how much money do you have to play with? typically, what you want is something that has more power than your max rating on your speakers...reason why is because at a volume that requires power that your amp doesnt have, you get a massive amount of distortion, even though your speakers can handle it...that will damage both your speakers and your fry your amp. if you have 75W RMS and 150W Max speakers at 4ohm, I would get an amplifier that has 200W per channel at 4ohm (200W x 4 = 50W per channel which is not nearly what you need for even your RMS rating)
also, dont run your 4ohm speakers at 2ohm...you will damage them...but one thing you can do, is double the length of the wire if your running from the amp at 2ohm and at the speaker, you will probably be around 4ohm...you will have to use a multimeter for that though just to be safe...i think its a multimeter at least...
Subwoofer: TC-9 15"
Old 05-08-2008, 04:34 PM   #7
HNaga's CarPC Specs
My Photos: (0)
I didn't thought so, I thought I would get AMP with RMS less than the speakers. in order to not to load the speakers, I don't like high volume , I care about pure detailed sound.
I'm not sure I understood the example.
you mean I need 200 watts x 4 channels?
Old 05-08-2008, 04:39 PM   #8
rijndael's Avatar
My Photos: (0)
even at low volume, it wont sound right...you will be asking for more power than you realize...try it your way first, but i dont want to have to say "I told you so" lol
yes...200 Watt by 4 channels equals 50 Watts per channel
Subwoofer: TC-9 15"
Old 05-08-2008, 04:48 PM   #9
HNaga's CarPC Specs
My Photos: (0)
it's 60 per channel I think.
look http://www.sonicelectronix.com/item_...BL+CS60.4.html
Old 05-08-2008, 10:50 PM   #10
My Photos: (0)
I have a question for rijndael, where did you get your information on amp selection and wiring. I also was wondering how do you run a 4 ohm speaker at 2 ohms?
dopey273 is offline   Reply With Quote
Sponsored Links
Old 05-08-2008, 11:04 PM   #11
Raw Wave
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
Hey rigndael,
you have a lot of misinformation and half knowledge scattered throughout this post.
first, for a moderate system he'll be fine. and all of his components will work together. infiniti speakers are known for their efficiency. What you are kinda referring too is called 'headroom' and yes, having an amp that is putting out 150 wrms per chan will give less distortion and have a cleaner signal if the gains are set right. But as long as his gains are set correctly and he's not pushing his amp into distortion by turning the volume all the way up... then he'll be fine.
I have no idea how you came about suggesting running twice the length of wire. nor do i understand how to run a 4 ohm speaker at 2 ohms unless you purchase some resistors.
to the op... if you already have the equipment, you'll be fine. spend the time and money on installation (aiming, mounting, sound deadening, tuning). If you haven't purchased the equipment you could benefit from a more powerful amp (gives you some extra sq and spl --volume--). To put it clearly, you'll hear a lot of people saying "too little power will kill a speaker faster then too much power" well... to be clear. if you have a 200 watt amp and a 5 watt amp, neither one of the amps are going to blow the speaker when set up correctly. What happens though is that if you have a 5 watt amp and you are always cranking it up to the max volume you are no longer in the amplifiers sweet spot and you are introducing distortion to the speakers. distortion is what kills the speaker. now lets say that you have a 200 watt amp. after you set your gains correctly you can turn the volume up much higher before the amp starts to distort the signal. Hopefully... this is within your preferred listening volume and you're safe. does that make sense now? to further illustrate. think of a go kart as your 5 watt amp, and a corvette as your 200 watt amp... the throttle is your volume. a go kart driving at 100 mph vs. a corvette driving at 100 mph... the go kart is going to fry well before the corvette will... [on the flip side, now drive them both around at 5 mph and you're not going to break either engine, (working within it's power limits) but you may not be happy with the speed]
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 05-09-2008, 05:03 AM   #12
HNaga's CarPC Specs
My Photos: (0)
@scott_fx thanks for your detailed reply.
For me I don't like high volumn , usually 16-18 - I just wanted to know they are suitable for each other or not. you can have 2 perfect componenets but not suitable for each other.
60X4 or 80X4 was better for the speakers?
thanks
Old 05-09-2008, 07:58 AM   #13
My Photos: (0)
Nice job scott, I was wondering where that info came from. I'm really interested in it's source. Especially the part bout the 4ohm 2ohm spker wiring and wire distance. The average spkr wire has .064 ohms... that's alot of wire to gain 2ohms..
Old 05-09-2008, 09:52 AM   #14
Raw Wave
scott_fx's Avatar
My Photos: (0)
thanks
High volume is kinda arbitrary though. volume isn't a standardized value and there is a lot more that comes into play. 60 watts rms to an infinity coaxial is going to be a lot louder then 60 watts to; say, dynaudio components. now... i said 'louder' i didnt say better. :-). And volume isn't the main reason why you'd want more power from the amp, remember my analogy about the go kart. so what's 'better' for the speaker and the sq... well 80 watts rms x 4 would be better then the 60 wrms x 4 if everything else is the same.
in my system i have an amp that is purely for my tweeters (8 ohms) and is pushing them at 75 watts rms. are the tweeters ever going to see that much power? def not but my amp isn't going to strain even at the highest listening volumes and that means clean clean sound (that gets quickly masked by my exhaust )
thanks
i think a lot of times people read something but dont fully understand it. car audio is very confusing and i have been caught in the past (well...even now i get caught sometimes ) making some generalization. but the op took it to the max on this one
M10k
My Car Pc Install
Old 05-11-2008, 08:04 AM   #15
Vehicle: 2004 Volvo S60r
My Photos: (0)
http://www.jblpro.com/pub/technote/spkpwfaq.pdf
http://www.jblpro.com/pub/technote/lowpower.pdf
Check out these two links for a better understanding of power handling.
Andy Wehmeyer
Product Marketing Manager
Harman Consumer Group
Mobile, Portable and Companion Products Division
AWehmeyer is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sound system recommandations? yaniv Car Audio 1 02-26-2008 10:05 AM
Has anyone installed a Dell SX270 wintha sound system? amccoy00 Power Supplies 1 12-07-2006 07:28 PM
Newbie Sound System chris51122 Car Audio 33 08-02-2006 06:50 AM
got sound? masch Newbie 20 11-17-2003 09:01 AM
How do you get sound in to your system??? DaPyro General Hardware Discussion 1 02-28-2000 12:10 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
