The MP3car.com Store
Thread Tools Display Modes
Old 05-08-2008, 11:49 PM   #1
OrangeSword's CarPC Specs
OrangeSword's Avatar
Vehicle: 2000 Nissan Frontier Crew Cab
My Photos: (0)
My CarPC Diagram
I've been working on a design diagram for my planned CarPC. I know little to nothing about car audio so I have been doing research and educating myself. My choice of amp is modest I think as I want to contuine to use my stock OEM speakers. Could some of the more seasoned car audio gurus in this fourm critque my diagram? Does it make sense? I am using the correct fuses and wire guages? I will not be using a head unit. Any help is much appreciated.
OrangeSword is offline   Reply With Quote
Sponsored Links
Old 05-09-2008, 06:29 AM   #2
Super Moderator
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
It looks good to me, including your wire gages & fuse ratings.
I promise that you'll want to upgrade the stock speakers at some point, though.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 05-09-2008, 08:52 AM   #3
My Photos: (0)
No doubt. This is just the first iteration. Thanks!
Old 05-09-2008, 11:30 PM   #4
My Photos: (0)
Would it be better to decrease the guage to 8awg for the wires inbetween the distro block and the PC and amp? Apparently its hard to find a distro block that goes from 4 to 12, but 4 to 8 is easier to find. I think I made a mistake on the fuse choice in the distro block anyway. It should have read 15A. If I switch to 8awg i would use 30A fuses.
Old 05-11-2008, 07:53 AM   #5
Vehicle: 2004 Volvo S60r
My Photos: (0)
Despite what everyone else says and what you've probably read, the 4 gauge wire is definitely overkill. Unless you're dying to spend a fortune on power hookup, there are much cheaper ways to do that. Run an 8 gauge from the battery to the amp and a 10 gauge from the battery to the power supply. Then, you can use a pair of cheap fuseholders and standard fuses at the battery and then you don't need another fuse in the back. The fuse at the battery protects the car in case the wire is shorted against the chassis somewhere. The only reason to use a fuseholder/distribution block is so you can run one wire from the battery, because that's easier than running a bunch. You only need two and an 8G and a 10G together will be easier than running a 4G anyway.
Also, contrary to what most people believe, a fuse at the amplifier rarely protects the amplifier.
Andy Wehmeyer
Product Marketing Manager
Harman Consumer Group
Mobile, Portable and Companion Products Division
AWehmeyer is offline   Reply With Quote
Old 05-11-2008, 02:52 PM   #6
My Photos: (0)
Very nice layout and diagram. When it comes to these systems they are pretty much cookie-cutter but it's nice to see someone spend the time to lay it out in drawing form. This is my first post here (lurking for some time) and looking forward to seeing what you do with your system.
zeusenergy is offline   Reply With Quote
Old Yesterday, 01:36 AM   #7
My Photos: (0)
What software did you use to layout that drawing? I'd like to do this with mine as well.
Jay
creaseguard is online now   Reply With Quote
Old Yesterday, 06:11 AM   #8
Super Moderator
My Photos: (26)
You can easily pull off diagrams like that in Paint Shop Pro, Photoshop, Visio or halfway decent drawing program.
My Worklog
Old Yesterday, 06:39 AM   #9
Kadyroff's Avatar
Vehicle: 2004/Chrysler/Sebring
My Photos: (0)
MS Visio?
Kadyroff is offline   Reply With Quote
Old Yesterday, 07:45 AM   #10
My Photos: (0)
Cool, thanks.
Jay
Sponsored Links
Old Yesterday, 12:40 PM   #11
My Photos: (0)
Quote: Originally Posted by Kadyroff View Post
MS Visio?
Yes I did it in Visio. 2007 to be exact.
Sponsored Links
vB code is On
Trackbacks are Off
For Sale: CarPC EZ v.2.5d stevent76 Classified Archive 0 12-23-2005 08:55 PM
CarPC Gets BLACKOUT! when monitor is connected! Sympotonic General Hardware Discussion 25 12-08-2005 03:30 PM
CarPC Digaram - Visio/SmartDraw/other? fireball106 Software & Software Development 6 09-14-2005 03:41 AM
Loud noice when turning on CarPC Andreas106rally Car Audio 4 11-03-2004 11:27 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
