The MP3car.com Store
Thread Tools Display Modes
Old 05-10-2008, 10:55 PM   #1
My Photos: (0)
Exclamation 4-channel amp hookup question
i have a sony 600watt 4 cahnnel amp and i went browsing at amp hookup kits today and the only kit i saw for 4 channel amps was for a 1400 watt max. i figured this would be way to much overkill and my amp would sound like crap, is that true? and could i get a 2 channel amp wiring kit to work on a 4 channel amp? i am only going to use the amp to power a sub so i don't care about front and rear sound..... any help would be greatly appreciated
Dsmoov is offline   Reply With Quote
Sponsored Links
Old 05-11-2008, 12:11 AM   #2
JimmyFitz's CarPC Specs
JimmyFitz's Avatar
Vehicle: 2002 Thunderbird V8
My Photos: (0)
An amp wiring kit usually consists of power wires, 4 gauge or 8 gauge, and a dual RCA cable for two channels. That is all you will need to run your subs. Be sure to get the right size power wires though. If you are using all four channels, get a Y-adapter to connect the long RCA cables to both front and rear channel inputs.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 05-11-2008, 10:23 AM   #3
My Photos: (0)
okay thanks!
Sponsored Links
vB code is On
Trackbacks are Off
which is better, 2 channel or 4 channel amp for 2 speakers champ Car Audio 3 05-29-2007 11:45 PM
Wiring a 5.1 centre channel into front left / right amp lines Goines Car Audio 26 12-20-2005 06:23 PM
FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp clean customs Classified Archive 0 05-21-2005 10:04 AM
WTB: Decent 4 channel amp tiggs Classified Archive 2 02-19-2005 01:43 PM
PC -> Amp and HU - Amp question Nokia6600 Newbie 2 03-24-2004 04:42 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
