The MP3car.com Store
Thread Tools Display Modes
Old 05-11-2008, 11:27 AM   #1
My Photos: (0)
installing subwoofers
i have a 2003 impala, and currently trying to install subwoofers, but i have ran into a problem i cant seem to find a hole through the firewall. and tips or ideas on how to do it? Thanks
red_wings02 is offline   Reply With Quote
Sponsored Links
Old 05-11-2008, 11:45 AM   #2
Vehicle: 06 VW GTI
My Photos: (0)
Look to use holes already going through the firewall. You will have some, somewhere in that car from other pieces of hardware wired to something in the passenger compartment.
Worst case, get a drill and make your own.
ASCI_Blue is offline   Reply With Quote
Old 05-11-2008, 12:06 PM   #3
My Photos: (0)
I assume you are looking for a hole to run a wire for your amplifer?
If so, it will depend on how large your wire is. I am using 0 awg, and I will need to be making my own hole.
Just be sure you are not drilling into anything important, and that the wire will be out of the way of anything.
Also be sure to place a rubber grommet in the hole so the wire does not get damaged.
ArcaneDreams is offline   Reply With Quote
Old 05-11-2008, 12:06 PM   #4
Tainted Love
Cris's CarPC Specs
Cris's Avatar
Vehicle: 2006 Renault Megane
My Photos: (0)
Try looking where the cable that openes the hood passes through the firewall...
Epia M10000
Travla C137
Opus 150W
7" MM400 V2 Touch Screen in Custom Dash
7" MM400 VGA Monitor
7" Monitors in Custom Headrests
Slim DVD
BU-303 GPS
iDrive Griffin Powermate armrest
USB Wireless LAN
Cris is offline   Reply With Quote
Old 05-11-2008, 12:10 PM   #5
My Photos: (0)
That will be a somewhat smaller hole. Not to mention that cable will most likely rub against any other wires placed in that same hole.
Bare metal wire rubbing against a wire connected directly to your battery = no no.
Old 05-11-2008, 12:15 PM   #6
Tainted Love
Cris's CarPC Specs
Cris's Avatar
My Photos: (0)
That depends from one car to another...for example, on my Renault, I was able to get a 2AWG through that particular hole, and the cable from the hood doesn't rub against it because it has a shield inside which is the actual cable that pulls the hood. The hole also has a rubber sorrounding so the cable doesn't rub against bare metal. Most cars I know (European ones) are exactly the same.
Epia M10000
Travla C137
Opus 150W
Slim DVD
BU-303 GPS
USB Wireless LAN
Old 05-11-2008, 12:17 PM   #7
My Photos: (0)
True. But it does depend on how big his power wire needs to be.
I have always made a new hole dedicated for the power wire only. Just feels more safe that way.
Old 05-11-2008, 12:20 PM   #8
Tainted Love
Cris's CarPC Specs
Cris's Avatar
My Photos: (0)
Assuming you have the room, that's the best way to do it.
Epia M10000
Travla C137
Opus 150W
Slim DVD
BU-303 GPS
USB Wireless LAN
Sponsored Links
vB code is On
Trackbacks are Off
Wiring two dual-voice coil subs to one mono amp venom889 Car Audio 23 04-24-2008 12:52 AM
Installing nGhost spuzzdawg Linux 5 02-12-2007 04:49 PM
Infinity Kappa Perfect 12vq Subwoofers Q-logic godraj Classified Archive 1 06-25-2006 08:37 PM
I need help installing a CD/MP3 deck on my 97 Neon Mic4 Car Audio 15 04-30-2006 12:30 AM
understanding subwoofers and their amps Song0330 Car Audio 7 04-21-2005 04:55 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
