The MP3car.com Store
Thread Tools Display Modes
Old 05-14-2008, 06:27 PM   #1
My Photos: (0)
Antenna to trunk
Hi all,
I just got my self an HD Radio, pretty sweet! I would like to hook up the stock antenna to the radio, which is located in the trunk. Is there a way I can do that? I have a Civic 03 and the antenna is on the rear glass.
Dgege is offline   Reply With Quote
Sponsored Links
Old 05-14-2008, 06:32 PM   #2
pancit175's CarPC Specs
Vehicle: 96 Talon
My Photos: (0)
Why not just get the antenna line from behind the radio?
" In the beginners mind there are many possibilities, but in the experts mind there are few. "- Shunryu Suzuki
PROGRESS:
[DONE&DONE] (Considering a redesign)
pancit175 is offline   Reply With Quote
Old 05-14-2008, 08:22 PM   #3
My Photos: (0)
I don't want to pass two more wires from the dash to trunk. I need two, coz I'll have one from the antenna to the HD Radio and another from the HD Radio to my aftermarket radio (which will be a backup in case comething happens to my carpc).
I was hoping that since the antenna is at the back, maybe I can tap in it somewhere near the trunk. My other alternative is to buy a dedicated antenna for my HD Radio (more money to spend tho!).
Old 05-14-2008, 08:44 PM   #4
rgarjr's CarPC Specs
rgarjr's Avatar
Vehicle: 98 Lexus GS300
My Photos: (37)
What kind of HDR did you get?
My carpc worklog
rgarjr is offline   Reply With Quote
Old 05-14-2008, 08:46 PM   #5
Vehicle: 96 Talon
My Photos: (0)
There might be a junction plug you can access in one of the rear pillars of the back glass, behind the panel there. Most likely behind the passenger side panel by the glass. If there is a junction plug you can access there, then you're golden. If not, you might have to cut it and solder on a new male-female motorola antenna plug in line to create the junction you'll need.
I would also check the loom of wires on either side under the seat if the panels by the window doesnt have the antenna wire.
PROGRESS:
Old 05-14-2008, 11:41 PM   #6
My Photos: (0)
It's the Visteon HDZ300, using Mitch's cable. It's awesome btw
Wow, thanks for the info! I will check it out as soon as I have time (probably not before the weekend). Will let you know!
Old 05-16-2008, 12:26 AM   #7
My Photos: (0)
I checked out a little, and it seems too complicated. I'm thinking of just dishing out the cash and getting another antenna. I wanted an amplified one and found this one on eBay:
http://cgi.ebay.com/ebaymotors/Hidde...spagenameZWDVW
Anyone got any experience with such antennas?
Sponsored Links
vB code is On
Trackbacks are Off
The search for a good am/fm antenna thread, all welcome. greatwhite General Hardware Discussion 28 07-03-2008 01:00 PM
carPC is in the trunk. USB radio dongle is in the trunk. OEM antenna jack... Sal R. Car Audio 1 05-14-2007 12:21 PM
Hacking a Holux GM-210 for external antenna (doesn't work) mpquattro GPS 9 04-22-2006 08:22 AM
would a omni ceiling mount antenna work in my trunk? aoLhaTer Wireless Communications 0 07-14-2004 02:33 AM
This antenna inside trunk lid?? AutoInnovations General MP3Car Discussion 0 02-12-2004 06:52 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
