Notices
Old 05-16-2008, 08:39 PM   #1
2 subs on 2 channels amp
Hello i have a kenwood KAC-Q62 amp with the following specs :
5 Band Equilization
High pass filter
2 OHM load capability
(4 OHM) 40W × 2 (20~20kHz, 0.8% THD)
(2 OHM) 55W × 2 (1kHz, 0.8% THD)
And i have 2 Kenwood Db+ 800W 4Ohms subs
What is my best setup ?
Should i wire each sub to one channel and thats it or you got any other openions ?
One more thing should i set my amp to LPF or should i disable it ?
Thanks in advance
shadowz911 is offline   Reply With Quote
Old 05-16-2008, 08:41 PM   #2
rijndael's Avatar
wow man...you need a more powerful amplifier for even one of those subs...
look up a term "underpowering". you will fry your amp and possibly damage your subs...
Trouble deciding on car speakers? Clicky Clicky
My Myspace page (view my pics for carputer worklog)
Speakers: DLS Ultimate Iridium 6.3 Link
Subwoofer: TC-9 15"
Amplifier#1 (Front Stage): DLS Ultimate A4
Amplifier#2 (Sub) DLS Ultimate A6
rijndael is offline   Reply With Quote
Old 05-16-2008, 08:52 PM   #3
CarComp's Avatar
Ya seriously! That will be a serious load for that amplifier. You are sentencing it to death. You need at LEAST a true 200w and that should be PER sub. I am running 2 subs each with its own 1000w amp. Now I know thats expensive overkill, but i had the money at the time. Your amps should ALWAYS be bigger than the subs "watts wise". So do your amp a favor and hook it to your front dash / door speakers. You will put it to its intended use, and your system will last MUCH MUCH longer, as well as sound better.
BTW: You can pick up a decent old model Lanzar Optidrive for less than a dollar a watt.
http://cgi.ebay.com/Rare-Old-School-...QQcmdZViewItem
Get MediaEngine !!!
Media Engine Download
CarComp is offline   Reply With Quote
Old 05-16-2008, 09:14 PM   #4
Well i got this amp on my door speakers and they got fried they were the ford stock speakers.
I've been running this amp with both subs for like 6 months now and nothing happened , it just cut off few times before coz i was using my stereo for like 3 hours continous.
I have another 4 channel amp but 2 of its channels are not working .. may be i can use this for my subs and the kenwood amp for my door speakers .. the other amp is 450W 4 ohms..
btw i have one more question
I had 2 speakers on the same enclosure of the 2 amps but they were disconnected and after 6 months i noticed screeching noise and i found out that the subs are moving the cone of the speakers and when the cone moves it's making this noice because this speaker got wet few weeks ago.
Is there any hope that i can fix this speaker ?
I know it's not wise to have speakers with subs at the same enclosure but that's how i got them used and now i seperated them.
Old 05-16-2008, 09:52 PM   #5
rijndael's Avatar
wow man...i have no clue what you just said...but you can always go to your local car audio shop (not best buy or Circuit City) and have them look at your equipment...
the speakers definately shouldnt be attached to the same box as the sub unless you have a way to block the sub from the speaker via a wall inside the box....know what i mean?
Subwoofer: TC-9 15"
Old 05-16-2008, 11:18 PM   #6
CarComp's Avatar
Wet speaker = trash. Don't use. Will fry amp. Notice the punctuation. Screeching usually means toasted voice coils.
Amps WILL always destroy old OEM speakers. Unless you have some super premium sound system in a new'ish' car.
Get MediaEngine !!!
Problem relocating amp and subs perrottela Car Audio 7 02-26-2008 07:13 PM
How would you wire in an amp and subs without rca outs? mikeym Car Audio 2 03-06-2007 01:37 AM
Amp and Subs BallinColin Car Audio 9 10-29-2006 09:16 AM
i want to install AMP AND SUBS IN MY 03JETTA yayareapimp69 Car Audio 7 05-08-2006 07:23 AM
MTX subs + Coustic amp markopolo311 Classified Archive 1 06-26-2005 12:01 PM
