Old 06-20-2008, 04:28 AM   #1
Mobo front panel sound and Mic
Hello:
I have Jetway 7F2WE-1G5-OC mobo
I want to use front panel R and L to connect to the GM but the mic does not work , I'm not good using jumpers , any help?
regs
HNaga is offline   Reply With Quote
Old 06-21-2008, 01:56 PM   #2
What do you need to use the mic for?
" In the beginners mind there are many possibilities, but in the experts mind there are few. "- Shunryu Suzuki
PROGRESS:
[DONE&DONE] (Considering a redesign)
pancit175 is offline   Reply With Quote
Old 06-21-2008, 02:56 PM   #3
for Car Kit , replying the mob calls
Old 06-21-2008, 05:55 PM   #4
Have you looked through your manual for the MB at all. All the information about connections and jumpers should be all illiustrated within the manual.
And what are you using to connect the MB pins on the board itself to the mic socket.
So from what I understand, you are attempting to use the front panel output as a mic input. The only way I can think of that would even make that possible is if your MB and operating system had support for HD audio.
IF this is the case and both are true, then when you plug in the device into the audio plug, the OS prompts you that a device was plugged in and asks you to assign this port for a specific I/O for audio. This feature may be turned off, so I would snoop around the audio settings.
PROGRESS:
Old 06-22-2008, 09:51 AM   #5
No I think I didn't explain well, I don't want to use the front panel output as a mic input
I want to use frint panel to conect to the GM , but using front panel makes the MIC not working due to jumper settings I think.
Old 06-23-2008, 11:19 AM   #6
I dont know what else to tell you but check out your motherboard manual for any instructions on how to do what you are trying to attempt, if it is even possible with your MB. If you can source your manual to here or provide a link so I can read where it states if/how you can do this then I can probably translate any instructions if you're having a hard time understanding what you need to do.
PROGRESS:
Old 06-23-2008, 11:20 AM   #7
By the way, what is "the GM" you are refering to?
PROGRESS:
Old 06-24-2008, 08:35 AM   #8
I mean the Amplifier, JBL CS60.4
Old 06-24-2008, 08:48 AM   #9
Here is the Mobo manual
http://www.jetway.com.tw/jw/ipcboard...ame=J7F2WE1G5#
Old 06-28-2008, 04:12 AM   #10
OK, now why aren't you just using the rear panel audio out jack?
PROGRESS:
Current solutions lacking? Mobo, sound, power consumption? sivart321 General Hardware Discussion 8 06-12-2008 01:33 PM
onboard sound for 5.1 AND Mic anupchavda Car Audio 13 03-02-2008 11:26 AM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 11:19 AM
LONG: Start guide to get multichannel sound for MP3, DVD, SAT, etc.? vettejock99 Road Runner 5 07-25-2006 11:17 PM
