Old 06-25-2008, 08:37 AM   #1
Hear XM/mp3 and gps over radio
I've been looking for a cheap way to hear my gps when it alerts while I'm listening to my XM/mp3. I've tried plugging them both into a y stereo connector and then into aux in. I've also tried using a fm modulator but that doesn't work either. The ideal gadget would allow the GPS to be heard louder than the music or just cut the music entirely. Somebody must have thought of this problem before . Antone have any ideas.
keng52 is offline   Reply With Quote
Old 06-25-2008, 10:37 AM   #2
Felix509's Avatar
if your computer is running the gps software, your frontend may mute the music for you.
Ours is the age that is proud of machines that think and suspicious of men who try to.
___________________________________
Current SYSTEM
AMD64X2 2.5
Xenarc
ZAPCO DSP-6
ARCAUDIO SE Amps
Rainbow Profi CS365 & Profi Vanadium 12"
Felix509 is offline   Reply With Quote
Old 06-25-2008, 10:48 AM   #3
Fusion Brain Creator
2k1Toaster's Avatar
I know RoadRunner can mute or just lower the volume by some percent while the nav directions are spoken and then put the music back up. Very helpful.
Old 08-11-2008, 02:19 PM   #4
MySQL Error
scott_fx's Avatar
you just need an audio mixer
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 08-11-2008, 05:33 PM   #5
I'm asking for a cheap way of doing it or a DIY way.
Old 08-11-2008, 10:42 PM   #6
2k1Toaster's Avatar
Just solder your audio wires together.
Not the best, is dangerous, so dont do it to high end stuff, but it is cheap and will work.
Old 08-12-2008, 08:59 AM   #7
Do you mean speaker wires? I tried putting my XM and Gps on a Y connector and plugged it into a FM transmitter and you couldn't make out what either on was saying clearly. Seems like their would be a really low cost way of combining two sources and have the gps overide the XM when it gives directions.
Old 08-12-2008, 02:12 PM   #8
MySQL Error
scott_fx's Avatar
search for mixer, there is a stereo/mono mixer on that site that is pretty simple
http://headwize.com/projects/showfil...=opamp_prj.htm
also search for the LF353 mixer ic and you'll find some other schematics
here is another thread i found after a quick search:
http://www.diyaudio.com/forums/showt...threadid=41763
M10k
My Car Pc Install
I want to listen to music (radio) while using GPS navigation ummagawd General Hardware Discussion 5 08-12-2008 12:49 AM
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 55 06-08-2008 08:54 PM
Garmin announces Mac GPS support for everything! skizot MacCar 11 01-31-2006 03:37 AM
What can cause radio interference with GPS signals? chilli_pepper GPS 12 05-02-2005 06:18 AM
