Old 06-26-2008, 11:47 PM   #1
mjgonegm is an unknown quantity at this point
How to wire and use 2 Car battiries?
I will be installing 2 battires in my car one under the hood the secound one in the trunk is it ok to run a the postive to the on in the hood to the postive to the trunk and then hook the neagtive to the ground in the trunk??
To simplify postive Hood to postive trunk
neagtive trunk to ground/chassis
mjgonegm is offline   Reply With Quote
Old 06-27-2008, 12:07 AM   #2
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Do a search for Split Charge Relay.
there have been a number of threads discussing the best way to do this.
Enforcer is offline   Reply With Quote
Old 06-27-2008, 12:14 AM   #3
nobb will become famous soon enoughnobb will become famous soon enough
Use a battery isolator.
nobb is offline   Reply With Quote
Old 06-27-2008, 12:16 AM   #4
is it ok to use the switch idea ?? so the batterys won't fight
Old 06-28-2008, 03:32 AM   #5
rgarjr's Avatar
rgarjr is an unknown quantity at this point
The way its done is, when the cars engine is turned on, both batteries are connected together so that they can be charged up with the alternator. When you turn off the car, the heavy duty relay (isolator) kicks off and now the 2 batteries are not connected.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 06-28-2008, 04:40 AM   #6
MindDrive's Avatar
MindDrive will become famous soon enough
click the '97 seville link... what you should do is use a battery isolator
the under-the-hood battery does nothing BUT power teh functions of the car, while the 2nd battery in the trunk (or wherever) powers nothing but auxilary componets (pc, amps, sterio etc)
the altenator connects directly to the isolator, its the isolators duty to determine which battery needs a charge, cheap ones just use diodes to direct flow at a certain voltage, where as some of the more $$ ones will by default start the charge on battery 1 (the under the hood) and once that is maintained properly, will direct charge voltage to the 2nd battery. the isolator im using i purchased at napa for like 70 bucks plus a $15 install connector kit for the GM altinators,
anyway,
the whole purpose of using an isolator rather than just connecting 2 batteries together (which can be done and does improve power output by connecting the +'s together and the -'s together) BUT if one battery slowly fails (due to bad cells, unstable fluid etc) then it will drain the other battery and you will eventually have 2 completely worthless batteries.
One way to combat this is by using 6V batteries in series **= 12V** and double that.. which will give you the equivalent of 2 12v batteries, but far more amps BUT with the extra weight and added wiring and overall cost its not something you would want in a common vehicle
One tip, the 2nd battery should only be a ***" dual duty deep cycle"*** marine style battery for several reasons:
they take massive drain beatings
they hold a charge longer
low maintenance
and if relayed right, or for emergencies, you can start a vehicle using jumper cables or your own vehicle by wiring a solenoid into the ignition or a switch
GL adding a 2nd battery
MindDrive is offline   Reply With Quote
Old 06-28-2008, 02:43 PM   #7
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Easy answer as stated: Battery isolator and the accessory battery should be deep cycle.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
xbox + inverter + remote start + relay switch ozstriker78 Power Supplies 10 08-24-2008 10:44 PM
How Can I Use Half of the Old Sproggy PS Wiredwrx Power Supplies 3 11-02-2003 08:40 PM
Attn: 15' foot 80 wire IDE works. Paid 16 buks. -DVD-ROM (Say Yes!) LESLIEx317537 General Hardware Discussion 30 02-14-2002 05:05 PM
