Old 07-01-2008, 11:13 PM   #1
carbump is an unknown quantity at this point
did i fry my amp
hi new peaple help! i installed an amp and woofer all wired right, except when i would turn it up loud the amp would go into protect. it was fine for a while until i turned it up all the way ,it went into protect but this time it stayed on protect for a while ,then when it did come back on there was no sound. come to find out the ground came lose, i tightened it still nothing ,what did i do ?
carbump is offline   Reply With Quote
Old 07-02-2008, 01:27 AM   #2
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
If it's still under warantee, then it's defective.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 07-02-2008, 02:25 AM   #3
audiology is an unknown quantity at this point
Does the amp still turn on? if not check the fuses.
And as for the previous problem it seems like you wired your subwoofers incorrectly thus causing the amp to go into protection mode.
[98%]
audiology is offline   Reply With Quote
Old 07-02-2008, 10:22 AM   #4
JPolito830 is an unknown quantity at this point
I agree that I think the wiring is done wrong...I would check the connections.
Owner of three automotive franchises, specializing in electronics.
JPolito830 is offline   Reply With Quote
Old 07-02-2008, 02:35 PM   #5
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Threads merged. Please don't double post.
System always under construction
durwood is offline   Reply With Quote
Old 07-02-2008, 02:53 PM   #6
Curiosity's Avatar
Yeah, subs wired in parallel as 1 ohm or 2 on a non 2 ohm stable amp could heat it up quick huh?
Engine Noise due to ground loop or amp? matt11601 Car Audio 30 08-26-2009 09:38 PM
Unusual amp shut off problem....please help! mike40370 Car Audio 12 12-05-2007 05:13 PM
Car Audio People, Help me pick an amp / Jeep GC w/ Infinety System hevnsnt Car Audio 3 12-07-2004 07:34 PM
Amp setup. Heat concern. d_sellers1 Car Audio 2 07-09-2004 10:58 AM
