The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 07-04-2008, 05:05 AM   #1
LTi
Vehicle: 2007/Ford/Focus II
My Photos: (0)
Exclamation I need quick help on speaker wires, please!!
Dear m8,
First of all i am looking for a help from Ford Focus II owners.
But others might help me too.
Anyway.
I have a Ford Focus II from 2007.
I would like to replace the factory speakers with something better.
The question is how much the factory audio or speaker cables can be used or needs to be replaced also.
My new audio configuration going to be max. 100W RMS.
Since it is very hard to pull in new cables through the factory connectors in each door i am thinking of using the old audio cable which is running from inside through some kind of connection block into the door.
What do you think of that?
Regards
LTi is offline   Reply With Quote
Sponsored Links
Old 07-04-2008, 07:08 AM   #2
AltimateX's Avatar
Vehicle: '96 Plymouth Neon Sport 5sp, '95 Nissan Altima SE 5spd, '92 Mitsubishi Galant, '84 Mercedes 190D 2.2
My Photos: (0)
You will be fine with the factory wiring. There is no need to replace any of it. You may have to change the connectors so they will plug into your speakers, but that's about it.
Are you still running the stock h/u? If so, I recommend replacing that before replacing any speakers.
AltimateX is offline   Reply With Quote
Old 07-04-2008, 07:11 AM   #3
LTi
My Photos: (0)
No, the factory HU has been taken out.
I am installing my CarPC now.
The amp that i have is a 6 channel one.
It has 5 x 100W RMS and 1x 250W RMS for the Subwoofer
Regards
Old 07-04-2008, 07:18 AM   #4
LTi
My Photos: (0)
By the way how much current and voltage does the amp has at it's outputs? (speaker side)
I think a lot more voltage than current right?
Becouse as i can see the factory cable is around 1mm thick,
so it can not have more than appr. 2A current flowing through it.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Quality of power, signal, and speaker wire? cherrybomb Car Audio 10 01-11-2007 06:55 PM
Powering your OPUS out of the car the cheap way with ATX PSU lloydy Power Supplies 17 02-17-2006 04:59 PM
Quick disconnect Box via cat5's lostreception General Hardware Discussion 8 06-17-2005 10:47 PM
Speaker wires question KyleYankan Car Audio 7 04-15-2005 03:01 PM
Power wires inquiry maxxell Power Supplies 18 03-27-2005 03:33 PM
Sponsored Links
Ad Management by RedTyger
