Quote: Originally Posted by
madrone26
Option 1 - use the optical toslink connection from the laptop to some sort of 5.1 converter that can process the dolby digital signal to analog, and from there to a 6 channel amp. Problem is, the only converter I've been able to find is the Pioneer DEQ p8000, and it seems to only work with the Pioneer DVD head unit. Is there another solution here?
This is mostly a lost cause, unless you are willing to implement more expense in amplifiers (multi-channel) and processor / controller combo. It can be done, but you're probably looking at $800 plus to go this route. That's with ebay pricing and that doesn't get into cables, install expenses.
madrone26
Option 2 - ignore the surround sound information, and just output a 2 channel stereo signal from the laptop. Being a total car stereo newbie, I have no idea how to split that signal so that the center speaker will produce some sort of mono. Help?
Is there another way to do this? My budget is not more than $800 - so it's not going to be audiophile quality.
If it makes a difference, the speakers are all 6 ohm.
This is the route you'll find more easily done ... but give of that center channel notion. Surround sound is really difficult to pull off in a vehicle. Just go stereo. The money saved and headache saved in setting it up will be worth it.
