Old 07-06-2008, 05:39 PM   #1
stevey500 is an unknown quantity at this point
Sirius radio having issues!
I installed Sirius radio in my Isuzu rodeo running Road Runner with DigitalFX skin..
Everything works great! I love it... the interface in DigitalFX isn't fantastic but hey, it works and it's pretty darn cool.
BUT.
it only works SOMETIMES when I resume from standby. . .
I'll resume, tap Sirius Radio... and I'm brought to the list of channels, no audio or titles/Artists... Sometime I can go back to the main menu and try again and it will work but that is rare. I usually have to go back to standby and resume, sometimes twice... and we're back in business.
I have a GPS hooked up too, the GPS is using XPORT to split it's port into two ports for use with RoadRunner and iGuidance...
Some people have told me to run the Sirius interface through XPORT but I already have XPORT being used unless it might be possible to run two instances ?
thanks.
stevey500 is offline   Reply With Quote
Old 07-07-2008, 11:50 AM   #2
pancit175 is on a distinguished road
Do you have the pins for that usb to stay on while in standby. The only thing I can think about other than software or major hardware problems is that while going into standby the device shuts off when power is taken away from the usb rail, and while it resumes it assumes that the device was still on. When in fact power is just getting to it and the device may not work properly because it is in a different state than the software believes. Just a theory.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 07-07-2008, 12:52 PM   #3
Good thought! But no, my USB output is completely shut off when in standby.. +5v power from usb is gone as soon as it is shut down or put into standby.
Old 07-07-2008, 03:50 PM   #4
dhantiflag's Avatar
dhantiflag is an unknown quantity at this point
i have simular issues sometimes using LSXVOID skin... mitch rewrote XM im just waiting/hoping he will do sirius...
dhantiflag is offline   Reply With Quote
Old 07-08-2008, 09:03 AM   #5
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
One option is to change the hibernate aware settings, yes i know you want to do standby but the concept is the same. When i used to hibernate, I had the same kind of issues that you're having with standby, setting hibernate aware to true worked in some versions of RR.
thanks.
There are additional settings in Xport to help bring USB devices back from standby/hibernate. It's the bottom section of the program.
"The device list at the bottom works much like DevCon, and is for devices that have trouble with hibernation. Check only the devices you have trouble with. XPort will stop the driver before hibernation, then start after resume, then retry any driver that fails to start a few seconds later. Use with caution. Some devices may freeze XPort or fail to disable or enable. Each device may add several seconds delay, so it may not be a good option to use. You can test each device by disabling/enabling in Device Manager."
Machinehead is offline   Reply With Quote
Old 07-08-2008, 06:14 PM   #6
My point exactly. You may need to devise a way to keep the +5v active while the computer is in standby.
PROGRESS:
Old 08-22-2008, 01:22 AM   #7
cameronlazzari is an unknown quantity at this point
Hey where are the hibernate aware settings?
cameronlazzari is offline   Reply With Quote
Old 08-22-2008, 07:43 AM   #8
In RRconfig, don't know which section off the top of my head though.
Old 08-22-2008, 11:32 AM   #9
I found it last night after reading looking for it. It is in the RR.in file. Didn't fix my problem...oh well
Sirius vs. XM Satellite Radio Pistolen08 Car Audio 9 01-29-2007 02:09 AM
Sirius Radio Etho Media Engine 10 09-20-2006 09:09 AM
FS: mitches PC Sirius radio adapter : Serial MP3_TJ Classified Archive 4 04-19-2006 12:51 AM
Kenwood Sirius Radio nick9871 General Hardware Discussion 0 10-03-2004 06:16 PM
Sirius satellite radio, can we control it with a PC??? JonEQuest General Hardware Discussion 1 12-20-2003 01:26 AM
