Old 07-11-2008, 01:30 PM   #1
JStar is an unknown quantity at this point
Connecting MP3 to aux
Hi,
I have a kenwood KVT-920 DVD head unit,
I want to plug my mp3 player in but when i plug it in via the AUX using an RCA to 3.5mm jack, the volume is alot less than when playing a CD about a third less.
Is there a reason for this or a way around it?
Many thanks
JStar is offline   Reply With Quote
Old 07-11-2008, 10:02 PM   #2
brucedog's Avatar
brucedog is an unknown quantity at this point
Although this is really a carPC forum...
The output voltage of your mp3 player must be lower than the internal cd player preamp.
You have turned the mp3 volume up as high as it will go w/o distortion in HU?
How about tone control settings for mp3 player?
Best of luck and blessings
Happy CarPC'ing!
brucedog is offline   Reply With Quote
Old 07-12-2008, 02:06 PM   #3
redcard2k7 is an unknown quantity at this point
i had the same problem with my sony head unit and found out that they make a thing called an ipod interface if an ipod is what you have...it is about 50 dollars at best buy and is very simple to install just plugging a few wires through the back of the head unit if you don't have an ipod, make sure the volume is all the way up on your mp3...i would suggest a fm transmitter if the volume trick doesn't work
redcard2k7 is offline   Reply With Quote
Old 07-12-2008, 04:34 PM   #4
Slypr's Avatar
Slypr is an unknown quantity at this point
If your player has a line out you might want to try that
headphone amp might work too
Slypr is offline   Reply With Quote
Old 07-14-2008, 08:22 AM   #5
How do you mean, my MP3 only has the headphone out?
Yea Kenwood make an IPod adaptor but mine is one of the few headunits that its not compatable with. it plugs into the CD changer port which i have but the specs say it isnt compatable?
Old 07-14-2008, 09:23 AM   #6
it may be compatable it it plugs into the back of the headunit which uses the rca cables and goes to a small box you mount at your own discretion....and then it plugs in
Old 07-14-2008, 04:07 PM   #7
Slypr's Avatar
Yeah, most do, but if it had a line out then it would be worth a try
Connecting MP3 to factory stereo Mazda 3 Fastwind General MP3Car Discussion 0 10-14-2006 05:12 AM
Connecting MP3 to factory stereo 01 mazda 323 coconol General MP3Car Discussion 1 09-27-2006 12:31 PM
Connecting an mp3 player through a cd-c (din connector) port? blackflag0101 Newbie 5 06-10-2006 04:20 PM
Connecting an MP3 Player into a Sony Stereo BigfootsMonk Car Audio 2 12-09-2004 03:23 AM
In dash car MP3 CD Costs mp3designer Classified Archive 7 02-06-2001 04:23 PM
