it's not a previous version, but actually just a different model. the .1 doesn't have the x-over's that you need and a very limited eq adjustments
http://www.rockfordfosgate.com/produ...(106185,106187)
what you are trying to do seems like a simple dac would solve your problems, i'm actually not sure why the x-fi isn't working either. have you tried troubleshooting your setup? first thing i'd do is hook up an ipod or other audio device with line level outputs to the sven adapter and rule out if it's an issue with the adapter first. then i'd hook up your x-fi to your home audio system and see if it's a problem with the soundcard.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
