Old 07-16-2008, 12:52 PM   #1
Tofiy is an unknown quantity at this point
Question Speakers stopped working
I have 2004 Passat, and ive been messing with fuses yesterday, checking them.
Today when i started my car i found out that none of my speakers work. although cd player is running. I checked the fuse panel several times already, everything is just fine.
CD player works fine too, there is just no sound coming out. I used to have a monsoon system, but i changed my cd player to Pioneer Premier FH-P800BT. I still have an external amplifier.
Anybody has a clue?
Tofiy is offline   Reply With Quote
Advertisement Sponsored links
Old 07-16-2008, 12:55 PM   #2
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
That's all you did yesterday is check fuses? And you're SURE they're all ok? Does your external amp have a separate fuse on the device itself? Also, how does it hook to your Pioneer deck? When you pulled fuses did it reset your pioneer's settings? Do you need to reprogram it to direct sound to your amp?
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is online now   Reply With Quote
Old 07-16-2008, 01:15 PM   #3
Ok everything got fixed couple minutes ago...i still dont know how.
I checked all fuses. It didnt help
Then i took cd player reconnected all cables, also reconnected wires to amp itself.
I also tried unpluging car battery. It all didnt help.
So i came here to write my first post...then i go back and it works :S
Iknow ure gonna say its a loose connection or something, but i doubt it.
Anyway main thing it got fixed.... im not playing with fuses again
Old 07-16-2008, 01:19 PM   #4
And answering ur questions.
No it didnt reset players settings when i pulled fuses out, although disconnecting battery sure did.
Im not sure aabout a fuse on amp itself, because amp is pain to reach.... i wasnt able to see much, except the wires, which i reconnected. I checked the fuse on player, and it was ok too.
Old 07-16-2008, 01:27 PM   #5
Tidder's Avatar
Hmm... prolly a loose connection or something... j/k
Not sure, that's strange. I was actually suspecting your pioneer HU as not putting the output to the right place.
Glad you got it fixed tho, nothing more frustrating than no music.
Tidder
Try RevFE
Best Quote EVER!!
Old 07-16-2008, 01:38 PM   #6
Ure right about "no music" part.
Thanks for ur help!
Old 07-16-2008, 01:43 PM   #7
Tidder's Avatar
Or lack thereof.
Tidder
Try RevFE
Best Quote EVER!!
Old 07-16-2008, 05:58 PM   #8
Woofnstuff's Avatar
Woofnstuff is an unknown quantity at this point
or worse.... the radio,
im wiring a decent amp in at the moment.. and tidying up the power feeds for the car pc. its all been running on "low" power till now and its finally ****ed me off so im going to finally install stuff properly.
but i forgot how annoying the radio is haven't listened to it for 4 or 5 months
Woofnstuff is offline   Reply With Quote
Old 07-16-2008, 10:10 PM   #9
Havent listened to radio in several years now.
Lilliput 629 stopped working numbr_9 LCD/Display 1 10-03-2007 11:33 AM
VGA on Jetway stopped working ajamils General Hardware Discussion 10 09-23-2007 02:47 PM
Help! Lilliput Touchscreen stopped working! tigergibb LCD/Display 3 09-16-2007 03:18 PM
1996 Chrysler Concorde front speakers not working getonerd Car Audio 7 03-11-2006 11:25 PM
Touchscreen stopped working craigyb Input Devices 0 04-07-2004 05:51 PM
