Old 07-18-2008, 01:20 AM   #1
steven765 is an unknown quantity at this point
Xenarc MDT-x7000 sound issues.. need advice
So I finally got to hear my x7000 in my car tonight... Annnd
There is a slight whine coming from it when it's playing a CD, not too bad, but I can hear it.
I also found that it doens't like the subaru stock sub. It was bottoming out the voltage on the unit causing it to skip. Though after I shorted a fuse and replaced it, it doens't seem to do that now so I dunno.
BUGS I've found:
The slowness of the volume dial is a PITA, but I knew that one.
It won't let you change tracks with the screen closed... but when the screen opens it issues the last command from the job dial.
Does anyone know how to change that horrible background image?
steven765 is offline   Reply With Quote
Old 07-22-2008, 12:10 AM   #2
legato27 is an unknown quantity at this point
Hi Steven, did u manage to solve the problem? I think my problems are quite similar.
legato27 is offline   Reply With Quote
Old 08-02-2008, 09:59 PM   #3
mrbryanjames is an unknown quantity at this point
I also have the same problem. I've read in another thread that the gain needs to be increased, but I have no idea what gain this is :-(
mrbryanjames is offline   Reply With Quote
Old 08-14-2008, 02:33 PM   #4
ricbw2 is an unknown quantity at this point
What firmware version do you have? It'll look like...
Firmware version is: Host : 297, Slave : 189.
To check the firmware version of your unit, press (on the remote) Memo (+), 4, 3, 8.
ricbw2 is offline   Reply With Quote
Old 08-26-2008, 07:00 PM   #5
southtarnation is an unknown quantity at this point
i have all the same issues. I have the firmware noted above...
southtarnation is offline   Reply With Quote
Old 08-26-2008, 07:59 PM   #6
Yea,
I got word back from xenarc, I'm going to try to RMA it. I have the older firmware that won't select the PC input when starting up.
However,
They documented the volume problem so it's a "feature"
As is the lack of control with the screen closed. They suggest using the remote when it's closed!! Because that's a great Idea when driving!! Ugh
Old 08-26-2008, 10:32 PM   #7
Haha Oh another thing with the 7000, They didn't isolate the ground on the USB, or the video outputs shielding. I found this out when I unplugged the unit ground and the system was still running. Tons of noise appeared and I went hrmph WTF, oh I bet, pulled the USB and video. Poof there's your ground loop.
Morale of the story, your head unit and car pc had better be on the same ground and pretty close at that!
Hardwire car sound so it will work throguh the xenarc? thaladyzman LCD/Display 13 02-25-2003 01:09 PM
Seeking sound card advice Adam F General Hardware Discussion 6 02-19-2002 11:11 PM
Sound quality issues when amplified? ryanjg11 General Hardware Discussion 4 12-28-2001 08:45 AM
Need advice on which sound card to use mtmsol General Hardware Discussion 2 06-22-2001 01:39 PM
How do these plans sound (need advice) mykolJay General Hardware Discussion 12 07-10-2000 02:05 PM
