Old 07-28-2008, 02:59 PM   #1
incudie is an unknown quantity at this point
DAC, multiple outputs?
Hello,
I am using a VIA M10000 and looking at using a DAC to get sound to my two amps.
One amp is controlling my front left and right comp set (passive x-overs), another amp is just for the subs.
I would like to have a DAC go from the PC to each amp. Is this possible? Or do I need two DACs (One for each amp).
Is it possible to get a Bloat DAC with multiple RCA outputs?
(Trying to grasp my options).
Thanks!
incudie is offline   Reply With Quote
Old 07-28-2008, 03:16 PM   #2
b3tts32's Avatar
b3tts32 is on a distinguished road
Not sure if I'm completely getting your setup but I think I have something similar. I have a 5 channel amp that outputs to a crossover for my highs, mids, and sub. From the crossover goes to my dac which is then connected to the computer. I don't believe you would need more than one dac but that is just me..
b3tts32 is offline   Reply With Quote
Old 07-28-2008, 03:23 PM   #3
Sorry not a very good description of my setup (heres a quick MSpaint version of what I was hoping to be able to do)
Old 07-28-2008, 04:51 PM   #4
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
there aren't any multi-chan dac's out there that i know of. well, they have multi chan ic's but not a dedicated dac. your best bet would be to go with a bloat or twisted pear dac into the stereo input of your amp, then use the amp's pre-outs to get the signal to the subs. the drawback is that you'll have to use the amp's x-overs but depending on your setup, it could be just fine
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 07-28-2008, 05:31 PM   #5
Hi Scott_fx,
Thank you for the suggestion. Unfortunately I'm having a hard time understanding. Are you saying, wire from the DAC to the 4ch amp then to the 2 channel amp?
Thanks,
Incudie
Old 07-28-2008, 06:24 PM   #6
MySQL Error
scott_fx's Avatar
yup, what amp do you have? some amps will have a pre-out that will pass the original signal on to another amp. another option is just to get rca y-adapter that will give you two identical stereo ouputs as well.
M10k
My Car Pc Install
Old 07-28-2008, 06:28 PM   #7
sweet thanks. I have an
Ipaul 4.300
http://195.243.203.21/rainbow/techni...112112&lan=ENG
Actually, I have not purchased the other amp for the sub yet
Old 07-28-2008, 07:15 PM   #8
MySQL Error
scott_fx's Avatar
http://www.talkaudio.co.uk/index.php...d=212&Itemid=1
-RCA inputs for four channels plus RCA throughput sockets
looks like you're good to go. nice amps btw...
hmm... if you're going the route of rainbow amps... what speakers are you going with?
M10k
My Car Pc Install
Old 07-28-2008, 08:20 PM   #9
Thank,
SLC 265 Kicks =)
Old 07-28-2008, 10:21 PM   #10
MySQL Error
scott_fx's Avatar
you should just run active and screw the dac :-)
M10k
My Car Pc Install
Old 07-29-2008, 12:14 AM   #11
That is what I've heard in the past... Active Crossover? How does that connect to the computer? Is that some kind Equalizer or are those completely different? (JUST finished sound deadening my passenger door...)
Old 07-29-2008, 06:21 PM   #12
Ok doing a little more research... I *think* I would still need a DAC.
Would Go:
PC > DAC > Active Cross Over > Amps > Speakers
Or do active crossovers have some kind of DAC built in? (don't believe so).
Old 07-29-2008, 07:10 PM   #13
b3tts32's Avatar
Would Go:
Yeah that's what my setup looks like right now, don't believe they have built in dacs
Old 07-29-2008, 08:31 PM   #14
MySQL Error
scott_fx's Avatar
look into the behringer DCX2496 (what i have) or the alpine h701 (had this in my last setup) for a more streamlined solution
either will be perfect for mids, tweets and a sub.
M10k
My Car Pc Install
Old 07-29-2008, 09:00 PM   #15
Thank you for the recommended main-stream devices. (looking at the manual for the DCX2496)
http://www.behringerdownload.de/DCX2...PECS_Rev_C.pdf
If I am reading this correctly, is there an S/pdif input?
I have a spdif port on my M10000, would that be any better or worse then using a bloat?
Carputer Help Multiple Video Outputs SuperEco06 General Hardware Discussion 8 04-13-2008 10:24 AM
Triggering multiple outputs with 1 image rgarjr Fusion Brain 9 04-05-2008 04:55 AM
usb non oversampling dac with us in mind scott_fx Car Audio 13 09-18-2006 11:46 PM
Multiple audio outputs schnaarf MacCar 10 08-04-2006 08:25 AM
Multiple Sound Outputs djXternal Car Audio 11 10-04-2004 03:58 PM
